Old 10-24-2015, 11:26 AM   #1
Plumbing
I need help again! In the rear driver side storage compartment of our Lexi 3005s is a capped plastic tube and a water pump associated with it. What is it and how do I operate it???
AZ How is offline   Reply With Quote
Old 10-24-2015, 11:49 AM   #2
Ford Idaho's Avatar
Anti freeze suction tube.
Drain water system including the water heater tank and low point drains.
Switch water heater by pass valves.
Put tube in AF and turn on the pump, you will likely need 2-3 gallons of AF.
If your unit has a water filter, remove the filter and place a capped empty water bottle inside and reattach the housing.
Old 10-29-2015, 09:32 AM   #3
dougpatz's Avatar
Empty water bottle in filter cylinder-Brilliant! 've never heard that one,and going to do it this year! Thanks :-)
Patti Z.
2011 Lexington 283
Husband - Doug
Springer Spaniel - Sheldon
dougpatz is offline   Reply With Quote
plumbing
