Old 04-09-2012, 05:59 AM   #1
Preping for 1st camping trip
we are preparing the unit for our first official camping trip. There are 2 city water connectors on the unit 8 inches apart and unmarked. Why are there 2 and which is the one to connect to the water source?
brokenspur is offline   Reply With Quote
Old 04-09-2012, 06:19 AM   #2
TURBS's Avatar
Post pics
Not sure I've Sean or heard of a reason for two city water connections.
I have to wonder if one is bw flush mislabeled.
Old 04-09-2012, 06:25 AM   #3
grhodes50's Avatar
I'm guessing one will be your black tank flush, but I can't you tell which. Hook up a water hose and you will be able to find out pretty easy or post what tt you have and someone with the same model should be able to help you.
Gary & Trish
2018 Nights Camped - 5
Old 04-09-2012, 06:28 AM   #4
Mountainmanbob's Avatar
thinking it was just
going the extra mile -- a good THING someone did
how often do we wish we had another hose bib ??
and did not have to use the little T valves
is this the only site there
or do all the sites have two hose bibs ??
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 04-09-2012, 07:47 AM   #5
Herk7769's Avatar
If you use this method to test; BE SURE to crack the bib valve and immediately shut it off. Check inside at a faucet for water pressure.
If you have water pressure at a tap. you have the correct connection.
If no pressure you have connected to the TurboFlush.
FYI, running full pressure water into the TurboFlush with the black tank drain valve closed can burst the tank. It is a warning in the manual.
HAM CALLSIGN - KC3FFW
Old 04-09-2012, 07:48 AM   #6
Glockfanjohn's Avatar
I have 2 hose connections net to each other as well. One is city water and the other is for anti freeze inlet for winterizing. Both are about 8 inches apart.
Best,
John
2009 Silverado w/5000 lbs airbags and P3 controller.
2013 Rockwood 2702SS
US Army Veteran
Glockfanjohn is offline   Reply With Quote
Old 04-09-2012, 10:47 AM   #7
pbrackney's Avatar
Yes you really have three options as to what the inlets are for.
1. City Water
2. Black Tank Flush
3. Antifreeze Winterizing Inlet
Mine has all three, but they are labeled.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 04-09-2012, 10:53 AM   #8
It might be helpful to list year, make, and model of your trailer.
Keith,Karen,Brianna, and Jessica
2015 F250 KingRanch, Powerstoke 6.7, 373 gears,
Prime Time Owner #81
2012 Tracer 3150bhd Delivered 10-22-2011
Nights Camped 2012 - 9 ,2013 - 7,2014-16
kwjeepxj is online now   Reply With Quote
Old 04-10-2012, 04:27 PM   #9
The manual didnt' come with this rig. That's my problem. Thanks for the warning.
Old 04-10-2012, 04:30 PM   #10
Thanks to everyone for the help. The top inlet was for the black water flush even though it was not marked. Haven't had one of those on my previous trailors. Nice feature.
