Old 02-19-2012, 05:20 PM   #1
Problems with exterior plastic cracking
2004 lexington 24' - the posterior plastic cap (that curves over the top edge and side exterior corners) and sides have several cracks - I've tried to plastic weld but not very successful. Forest River want's $1000 for the part - any ideas - thanks a bunch
jlfr is offline   Reply With Quote
Old 02-22-2012, 09:55 AM   #2
Head Rambler
That should be fiberglass and I'd check with a local boat repair place to see if they'll work on it.
Gotta go campin!
Old 02-23-2012, 01:38 PM   #3
GM
bclemens's Avatar
2004, I think it was ABS
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-23-2012, 02:28 PM   #4
Yes, it is ABS - I've tried to plastic weld without much success.
Old 02-23-2012, 04:38 PM   #5
Witch Doctor's Avatar
If you body is gel coat, it is really the same product that the boat ind. uses. I had a boat for along time, I have even sailed over 15000 blue water miles under the keel. What happens is that moist will enter and cause splits or blisters. The best product to use is called red devil. becareful how you apply it and clean the area and dig in to get out all the loose or desperation area, it is very hard to sand but will become stronger then the gel coat. Then touch up with paint, it will not seperated after that. You can buy it at a marine supply store such as west marine
Old 02-23-2012, 05:10 PM   #6
I will look that up - I have also contact an autobody shop for suggestions.
