If you body is gel coat, it is really the same product that the boat ind. uses. I had a boat for along time, I have even sailed over 15000 blue water miles under the keel. What happens is that moist will enter and cause splits or blisters. The best product to use is called red devil. becareful how you apply it and clean the area and dig in to get out all the loose or desperation area, it is very hard to sand but will become stronger then the gel coat. Then touch up with paint, it will not seperated after that. You can buy it at a marine supply store such as west marine
