Hello and thanks in advance for your help. My wife and I are getting ready for our trip out west for 4 to 6 weeks and in the process noticed the rear drivers side back up light is burn out. We have a 2010 FR Lexington, GTS. Well after looking the problem over I know I can see the bulb from the outside but do not see any way to remove it without removing the black weather seal. Looking from the underside they have it covered by a stapled box and as you can see spray foamed all around it.
Any suggestions would be appreciated and I'm holding off to see how others have handle this problem.
The lens is held in by the seal. You'll need a small thin blade screw driver, or a kitchen knife with a rounded tip. Just insert it into the rubber seal and you can insert it under the lens. Just work it out .
Easier to re-insert it if you give the seal a quick squirt with some silicone spray, or even a bit of soapy water around the seal.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Lewis, if the lens dosen't come off, it may be a sealed LED light, in which case the light has to be replaced. No way to repair it. If lens does come off, than it's probably a regular bulb.
Grumpy
Just google up 4 inch backup lighting (actually 4 5/16 inch)
Bunch of sites come up, including Amazon.
Check Bargman Lighting, Peterson Lighting. They carry mucho mucho styles, including the round back up lights.
Grumpy
We had the same issue driving at night with the rear brake/ turn signal. Stopped at O'reilys and they had it in stock. Fixed quickly and back on the road
