Replacement for rear 15" TV in 2008 283GTS
We have a 2008 Lexington 283GTS and the rear 15" flat screen needs to be replaced. It is not digital ready and we would need a converter box to get OTA digital signals. The TV is mounted in the top door and swings out for storage behind the TV. Has anyone replaced this TV with a 15" or larger LED TV and how did you make it fit. Also, on the wiring diagram that we got from forest river there is a Antenna Booster switch SOMEWHERE but I cannot locate this switch. Any suggestions as to where it is located? Thanks
