Old 09-23-2016, 03:11 PM   #1
Sewer hose storage
I can't believe the factory didn't make enough room for a basic sewer hose and accessories. But in either case, I purchased a SantiTube but because the mounting brackets come fixed it limited where I could install it. I originally wanted to mount it underneath near the Black Water valve.
So I ended up mounting it on the rear bumper and because of the ladder I could only get 59" but that holds the Rhino and the accessories you see in the picture. But its tight, and another inch would be perfect.
The PVC tube is a dull color and I wish it was like a normal PVC tube that looks shiny. If I had to do it over I think I would consider this other company that allows you to make your own. Or ask Santitube to provide additional support brackets.
Sanitubes / Sewer Hose Carriers / NEW!! SUPER-SLIDER Adjustable SUPER-TUBE - DW Inc.
Tube Door Kits for Schedule 40 PVC Storage Tubes | US Tube Doors
ostbob is offline   Reply With Quote
Old 09-23-2016, 03:36 PM   #2
Briorick's Avatar
Looks Great! Seems we are all a bit ANAL in our own sense of wanting things to blend. Could have bought some Krylon Spray Paint for plastics and possibly customized the tubing color to match your Coach.
Still, looks great though.
Rick & Brian
1 Happy Camper Pup ( Mya )
2016 Salem Cruise Lite 171RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 09-23-2016, 06:14 PM   #3
FLORIDA F.R.O.G.
RickLSmith53's Avatar
Hose Storage
My fix may not be for everybody, but I bought a large piece of sheet metal and did a lot of bending and shaping to form a compartment out of the open at the bottom sewer compartment on my 255 GTS. I am able to store my sewer hose where it should be stored now.
RickLSmith53 is offline   Reply With Quote
Old 09-23-2016, 11:03 PM   #4
I bought a very and I mounted it underneath by the black water valve now it is out of sight and I can easily pull out my hoses when I hook up
fulltimingary is offline   Reply With Quote
Old 09-24-2016, 06:28 AM   #5
We had the same thought, how is a sewer pipe suppose to fit in there? We bought a piece of pvc pipe, a few fittings, paint and clear coat to match the rv and mounted it to the rear bumper. Then we slid a piece of vinyl gutter in it to act as a "slide drawer" to make it easy to clean it as well as get the sewer pipes in and out. Works like a charm!
Copacetic is offline   Reply With Quote
storage
