07-13-2017, 06:06 PM
Sewer hose storage ideas
We originally installed an expandable Santitube on the rear bumper but it didn't really hold up to well. It's very thin tubing so it buckled under the AZ heat. So now I have to rethink things.
I was going to take the flip up Doors off of the ends of the Santitube to use on a regular 4" black PVC but the inside diameter is too small for our RHINO sewer hose connections. Plus the outside diameter on a 4" pvc is 4.5" which is smaller than the Santitube Doors I took off. With the RHINO hose we need at lease a 4.5" I.D. pipe.
Would be interested in seeing pictures on how and what others are using on their Lexington RVs.
Pic's would be greatly appreciated.
07-13-2017, 06:36 PM
I just did this yesterday. So easy. Go to Lowes/Home Depot (etc) and get a 5" post for vinyl fence. get two caps. I painted the white vinyl black and used two large hose clamps to attach to frame. I used two frame clamps to attach the hose clamps to frame so I didn't have to drill...
07-13-2017, 07:34 PM
X2 on the 5" fence post sleeve. It will be found in white looks like we're all painting them black.
07-13-2017, 07:50 PM
Originally Posted by john5646
X2 on the 5" fence post sleeve. It will be found in white looks like we're all painting them black. Attachment 144635
Nice Job!
07-14-2017, 01:47 PM
We did something similar in our Georgetown - but we also added a "slide" made out of plastic gutter (with 2 end caps attached) and a handle to make it easier to pull the sewer hose out of the fencepost. We have 2 10' sections of Rhino hose and it all fits plus the hose cleaner attachment. The 90 degree elbow does NOT fit however, so that is stored in a different location.
i'd highly recommend the slide - it's super easy to make with some rivets and a drill.
Garren
2015 Georgetown 351DS
2016 Jeep Wrangler Unlimited Sahara
Chris, Garren (humans)
Edgar & Carlos (felines)
RIP Sophie, the sweetest cat ever.
07-14-2017, 02:07 PM
2011 Georgetown 350TS
Chrisandgarren can you please post a pic of location of where you put hose? I have a Georgetown and have made the container but can't find a place to put it. Thanks
07-14-2017, 02:47 PM
You guys are a lot smarter than me I just put them in a bucket and shut the lid.
Former Owner of
2016 Cedar Creek 36 POS (My Last FR Product)
07-14-2017, 03:52 PM
Put 8' 5" fence post on back bumper with 4 long hose clamps. I stick in the hoses and put the caps on and we're under way. I do put 2 self drilling screws in each end cap just to make sure they can't fall off. Don't want to lose my hoses on the highway.
07-14-2017, 04:28 PM
6"x"6" white vinyl fence post covers that are 8' long. Attach to frame with 4 "L" brackets.
Get end caps and tool box latches. Rivet them on. Make sure to use an appropriate washer backer on the rivet so it doesn't work it's way loose.
07-14-2017, 04:36 PM
Originally Posted by DJP6371
Attachment 1447686"x"6" white vinyl fence post covers that are 8' long. Attach to frame with 4 "L" brackets.
Love this idea! Assume you have one latch on each side or is it hinged?
07-14-2017, 04:40 PM
Yes and on both ends so the tube can be hosed out.
07-14-2017, 06:57 PM
RailwayRog
5" SDR 35 pipe and caps
Can't find this type of pipe in local hardware stores, had to go to a specialty pipe business.
The other end stops short of the drive shaft by about an inch or two, never had a problem with this setup.
07-14-2017, 09:43 PM
Look what I've done to my 2012 Lexi265DS
Abouth 30 inches behind the wheels, I found that the C Steel frame was already drilled. So using treaded rods and folded (by myself) sleel bars I fixed the 5in. PVC post tube and inserted Vynil gutters for easy assist. The gutter also can be used to maintain the sewer hose the proper way.
07-14-2017, 09:45 PM
07-14-2017, 09:48 PM
Could't add picture, Sorry
The sqare tube is located 30 inches behind the rear wheels. I found the idea on the web for trailer and %th whells.
07-14-2017, 09:55 PM
I have what might be a dumb question (apologize in advance)...what's wrong with using the the bumper itself to store the hose?
I have the rhino hose and fittings, and it all fits inside just fine. I did replace the bumper caps with new rubber ones (2 years ago) after hearing that they might pop off and have never had any issues.
Eric & Abby
2016 Rockwood Roo 183
2014 Ford Explorer Sport
07-14-2017, 09:57 PM
Sorry, I didn't see the post location. I'm not familiar with the Lexington, so the bumper storage might not be possible.
Eric & Abby
07-14-2017, 10:07 PM
Some Lexington models, as my 2012 265DS, don't have the «square metallic tube bumper»; The rear is a molded end cap. The provided sewer hose storage bin is a premolded 22inches long x 4in dia tube: useless.
07-15-2017, 09:35 AM
Sliding the hose in and out of the bumper tube will eventually wear holes in it. I did the white fence post thing too, but added a 5" U shaped gutter inside to lay the hoses on, and now I can slide them in and out of the tube without damage.
07-15-2017, 05:47 PM
Sure! Its diagonal from the propane tank to the battery box. Sits on the frame, held in place with heavy duty cable ties.
