Old 05-11-2015, 04:52 PM   #1
Send a message via AIM to NoviBill
Simple questions: AC & Water Heater
So I had an OLD hybrid and had to light the water heater, my 2006 255DS has a switch, do I need to do anything other than turn the switch on? (I do know about the bypass and making sure water is in the tank).
On to the AC - I can turn it on and off and adjust with the thermostat, but the cold air only comes out of the AC unit. I see vents all over the ceiling and they are not producing cold air. Is there something I need to switch to get them working?
Thanks,
Bill
Bill & Renee from Novi, Michigan
2006 Lexington 255DS
http://anunbalancedbalance.blogspot.com/
NoviBill is offline   Reply With Quote
Old 05-11-2015, 04:54 PM   #2
TURBS's Avatar
Water heater "turn on switch" done.
Do you have a gas/ electric water heater?
If so you'll have a switch for electric and a switch for propane.
A/c- shut off quick cool vent on a/c.
The quick cool dump vent is used to cool down the main living area quicker.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-11-2015, 05:01 PM   #3
markb5900's Avatar
If so you'll have a switch for gas and a switch for propane.
TURBS
Just to clarify a little, look at the AC on the ceiling, there is a 'slide" somewhere on there and all your AC is probably coming out of that spot. Slide it over and that will close that vent and force the air to come out of the ducted vents you are seeing in the ceiling.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 05-11-2015, 05:05 PM   #4
Ford Idaho's Avatar
TURBS
"Gas and propane"?
Do you mean like Coleman fuel?
Old 05-11-2015, 05:06 PM   #5
TURBS's Avatar
Originally Posted by Ford Idaho View Post
"Gas and propane"?
Lol opps! I'll edit it
TURBS
Old 05-11-2015, 05:12 PM   #6
My water heater is propane gas.
Thanks for the replies, gives me peace of mind that all is well.
heater, water, water heater
