Old 04-10-2015, 12:33 PM   #1
drron's Avatar
single valve rear tires
I just got this 2006 GTS class B 25.5 ft.
Went to put air in rear tires and I only see one valve that goes to the inside tire.
Anybody know where the valve is for the outside rear tire
drron is offline   Reply With Quote
Old 04-11-2015, 10:23 AM   #2
RV Nomad
Look in the rim 180 degrees (or directly opposite) the inside valve. You may have to reach in and feel for it. If you can't find it, you may have to remove wheel cover to see it. Good Luck.
olygene is offline   Reply With Quote
Old 04-11-2015, 02:17 PM   #3
drron's Avatar
I'll check it out
Old 04-11-2015, 02:29 PM   #4
drron's Avatar
Just a confirmation you are correct. They are directly across from the inside valve but I don't know how you would ever get an air hose on it. Might need extensions.
Old 04-11-2015, 02:33 PM   #5
Ford Idaho's Avatar
Just this.
Old 04-11-2015, 04:04 PM   #6
drron's Avatar
Thanks, I just got some braided valve extensions from O'rielly's.
They include a clamp to the wheel.
tire, tires
