Old 08-17-2016, 01:42 AM   #1
snags1962
2008 Lex 255 DS. Emptied black tank but it still showed full on the elec panel. Also get an odor when start up after a period of sitting. Any ideas ?
snags1962 is offline   Reply With Quote
Old 08-17-2016, 01:24 PM   #2
Black water tank
I would suspect that thier are still some solids hung up on
the side wall sensors of your black tank. A good flushing of
the tank, by any means you prefere, should solve your problem.
tinkerman is offline   Reply With Quote
Old 08-17-2016, 08:25 PM   #3
FLORIDA F.R.O.G.
RickLSmith53's Avatar
Tank gauges
First I would install a Black Tank Flush Kit." Due to this very problem, I installed one shorty after buying my Lexie. The other old-timer trick is to run some water back in your tank before heading from a trip, and dump a big bag of ice into the tank through the toilet. That will usually break loose even the most attached goodies!
RickLSmith53 is offline   Reply With Quote
