Old 06-29-2015, 11:15 PM   #1
short fuse
tail light bulb replacenent
hello all
got a 2008 lexington GTS 283 Need to change back up light bulb got one answer that the grommet was to be pushed to center then entire fixture pushed to inside then disconnect and replace. I am confussed. is it a bulb or entire fixture to replace. where can i find the fixture replacement?
applehead is offline   Reply With Quote
Old 07-20-2015, 04:47 PM   #2
Try walmart or auto parts store. Maybe even a trailer supply. They are a water prof fixtures.
dunk05 is offline   Reply With Quote
Old 07-20-2015, 09:39 PM   #3
short fuse
Tail light replacement
Thanks for your input found that the lights are a seal unit common to truck stops stirs auto parts etc
light
