Old 03-22-2015, 10:07 AM   #1
Trouble with electric step
The step on my 2007 Lexi has apparently stopped working. I can hear the motor wanting to start and a tiny little bit of step movement occurs, but then it stops. I have it hooked up to my house power just to make sure that it isn't the battery being low. This started as an intermittent problem during the winter and I wondered if it was due to the cold, but it's 55 out today and not working. Anyone with experience with this out there that could give me advice on something to look at or lube?
heb1024 is offline   Reply With Quote
Old 03-25-2015, 08:13 PM   #2
Well it magically started working again. Is it possible that the battery was so low that it needed to be charged for a while before it would work, event though I had the camper plugged into my 20 amp house power?
Old 04-17-2015, 08:19 PM   #3
Hamm123's Avatar
My SCS/frigette step is making a noise when I turn ignition on or flip the switch inside the coach by the door but will not retract the step. I am going to look at the ground in the morning and the magnet on screen door. I sure hope it's something simple for the mechanically challenged guy.
Hamm123 is offline   Reply With Quote
Old 04-17-2015, 08:24 PM   #4
That is exactly what mine is doing. It works intermittently and then stops again. I will be interested to hear what you find when you look - I am quite sure I am less mechanical than you.
Old 04-17-2015, 08:30 PM   #5
Hamm123's Avatar
I will let You know, I did a search and have found some things to try.
Old 04-17-2015, 08:54 PM   #6
Great!
Old 04-18-2015, 07:44 AM   #7
Hamm123's Avatar
Name:   ImageUploadedByForest River Forums1429360582.228005.jpg
Name:   ImageUploadedByForest River Forums1429360613.527932.jpg
Name:   ImageUploadedByForest River Forums1429360634.109927.jpg
Name:   ImageUploadedByForest River Forums1429360697.251774.jpg
Well, I looked at screen door magnet and wire connectors beside the door step entrance and just jiggled the connectors and now it is working,,, thinking about trying to solder the wires. I am glad the step is now working!
Old 04-23-2015, 07:57 AM   #8
FLORIDA F.R.O.G.
RickLSmith53's Avatar
Electric Step Troubles & Fix
If your step is oscillating back & forth, you may have stripped the plastic spacers around the large gear in the gearbox. This can easily happen if you step on it with full weight as it is going in or out. Many of the Kwikee steps use a late 90's Ford Taurus drivers side power window motor assembly. If the motor is OK, you can usually use the window motor rebuild kit available from most auto parts stores, or eBay. (+_ $15.00) It is called a Ford Power Window Power Gear Kit. You can also find vids on YouTube showing you how to do the job... Or you can get the replacement motor assembly from Kwikee for about $200.
RickLSmith53 is offline   Reply With Quote
Old 04-23-2015, 08:34 PM   #9
Thanks Rick! I will check that out! The motor still seems okay as it is still trying to open the step but seems to run into a block - then every once in a while it will work. More often than not now it doesn't work though.
Old 04-26-2015, 03:17 PM   #10
Lexi2007's Avatar
Coincidence
Our 2007 Lexi step quit working in the extended position. We can hear the motor working [right now it's on shore power] but it's not budging a bit. The MH has been sitting on property for a while and the soil is quite sandy. I suspect maybe some sand might have gotten into it when it rained. The other thing is I accidentally flooded the unit and I'm wondering if some water seeped somewhere it shouldn't have and that has something to do with it. Hoping we can figger this out on our own.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
electric
