Old 12-04-2006, 12:25 PM   #1
TV Outlet
We have a 2005 255gts. Can anyone tell me, before I yank it out, if the TV is plugged into an electrical outlet directly behind the TV or elsewhere?
Gale Force is offline   Reply With Quote
Old 12-04-2006, 01:26 PM   #2
Bear's Avatar
Thumbs up
First off welcome to the site. About that TV, I would think it is plugged in behind the set. What kind of TV is it? If you could post some pics it might help.
Cheers
Bear
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 12-04-2006, 04:14 PM   #3
I guess we should have investigated a little before we asked the question. We just took a look. The TV, a Magnavox, is in a cabinet on the right side. It plugs into an outlet in the cabinet on the left side of the rig. Thanks for your thoughts on this.
Old 08-31-2007, 05:52 PM   #4
2006 Lex 283 buyer
Hi, Hubby and I recently bought a used 2006 283gts with 3 slides. The TV is on the right side; CD player in center; cabinet to hold VCR, etc. on left side. On left side compartment on the right there is a panel that can be removed. This is where my husband found the wiring; cables, etc. There is also a switch in this location to use when using "cable" or "stationery antenna" - check switch out. Maybe this might help.
Beach1babe is offline   Reply With Quote
Old 08-31-2007, 06:57 PM   #5
Welcome to FRF.
Ours is in a cabinet directly behind the TV. Not hard to see. In fact it is made for easy access; we can take the TV out and bring it outside where there are more outlets. How do you like your Lexington so far. We absolutely love ours.
J.R.
J.R. is offline   Reply With Quote
lexington
