Old 01-14-2013, 09:55 AM   #1
FLORIDA F.R.O.G.
RickLSmith53's Avatar
Water Heater Shut Off???
I searched my Lexi 255 GTS from top to bottom for a way to turn off the electricity to my water heater when stored, but plugged in. I live in an RV housing community in which all the homes have an RV Port, RV Garage, or are sitting on a landscaped RV Pad. So it is plugged in at all times. The only switch I could find was the one that fires up the W.H. on LP gas. This still strikes me as odd, because every RV I have owned that had an electric/gas water heater had both a switch for the electric, and one for the gas...? Well, it is an easy fix on the Lexi 255 GTS. The Converter/Circuit Breaker box is located under the bed. So I took the output from the water heater breaker and run it to a household style light switch I mounted also under the bed nearby. Then of course connected the output of the switch back to the feed to the water heater. I also placed a red lamp in the circuit so I can see when the water heater is running on ac. If you are not comfortable with electriciy and wiring you may want an RV repair center do this job. I just did not wish to wear out the heating element, or especially, waste all the electricity! Hope this is helpful.
RickLSmith53 is offline   Reply With Quote
Old 01-14-2013, 10:05 AM   #2
lindy's Avatar
Knowing the make or model of the water heater would make it easier. My elect/gas WH has the elect switch right on the water heater itself, it's behind the gas manifold you have to sort of bend down and then look up behind it to see the switch on mine.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 01-14-2013, 10:08 AM   #3
AREA51's Avatar
These comments are from the Berkshire Forum Forest River Forums > Motorhomes > General Motorhome Discussion > Berkshire Hot water tank - source switch
There should be an a/c on/ off switch on the actual Hw heater.
Open door and look in the lower left corner.
It's hidden so look close.
If you look at the Power switch located on the Hot Water Heater you will notice it has a small hole thru the rocker. This is for a small hairpin cotter pin that when stuck through the hole prevents the switch from being turned to the on position. When this is inserted it will avoid putting power to the heating element. Anytime the switch in the on position and the circuit breaker is also in the on position there must be water in the tank or the heating element will burn out. I make it a practice to avoid using the circuit breaker and always keep this switch in the off position until I hook up to water and shore power. I'm out of the coach anyway for the hookups and it only takes a second to flip that switch. I can only imagine the hassel to replace the heating element or the whole heater.
You can operate in both the A/C and gas mode at the same time, if fast hot water recovery is needed, we tend to use just propane when either boondooking or on the road and go to strictly A/C when using campground power.
The switch and red light indicator next to it in the power center is for propane operation.
McMaster-Carr
AREA51 is offline   Reply With Quote
Old 01-14-2013, 10:14 AM   #4
TURBS's Avatar
Suburban style hw heater on off switch
Old 01-14-2013, 10:44 AM   #5
FLORIDA F.R.O.G.
Water Heater Switch
I guess because I am now an "old fart", I need a red light looking me in the face to remember to turn it off! All RV's I have owned had it right on the main panel where the LP gas W.H. switch is... And had the red lamp to show if it was on. I guess I am spoiled and missed that feature.
Thanks,
Rick Smith
Old 01-14-2013, 11:04 AM   #6
TURBS's Avatar
My sabre has both switches inside .
Most fr products don't.
Turbs
Old 01-14-2013, 01:10 PM   #7
lindy's Avatar
RickLSmith53; Being an even older fart, what I do is I have a red tag I hang on the outside of the WH door when I turn the switch on while camping. Then during tear down I shut the switch off and put the red tag inside the WH ready for use the next time I turn the WH switch on. So far this has kept me from buring out the elect element being as I plug in the elect while trlrs at home but no water.
F.R.O.G. member
Old 01-14-2013, 01:16 PM   #8
TURBS's Avatar
Another option is to leave hw switch on and shut the breaker off in the distribution panel.
Again just don't forget!
Turbs
Old 01-14-2013, 02:15 PM   #9
Capt. Mike's Avatar
I clip a red plastic clothes pin on my water heater door to remind me to turn the electric power off when leaving a campground. I do the same thing with a red clothes pin on the antenna crank to remind myself to put the antenna down, too!
One of these days, as I get older, I'm gonna' have to clip a red clothes pin on Danforth.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 01-14-2013, 02:18 PM   #10
Capt. Mike's Avatar
Turbs,
Really like the two switches for the gas and electric oeration of the w/h on the panel of your Sabre.
Mike
Mike and Yvonne
