Old 04-29-2012, 09:34 AM   #1
Exclamation Where is the fresh water tank -2008 -283gts
CRAWLED AROUND THE UNDERNEATH THE COACH YESTERDAY FOUND THE GRAY WATER TANK/BLACK WATER TANK/GAS TANK, BUT FOR THE LIFE OF ME COULD NOT FIND THE FRESH WATER TANK?
I KNOW IT IS THERE SOMEWHERE, BECAUSE IT IS HOLDING 1/3RD OF A TANK OF FRESH WATER, WHICH I WANT TO DRAIN OUT.
SOUNDS SILLY BUT NEED SOME HELP HERE?
MIKE CRESS
MSCRESS is offline   Reply With Quote
Old 04-29-2012, 10:00 AM   #2
Not sure about the Lexington, but some motor homes, the tank is under the bed. Regardless, it won't be too far from the fresh fill inlet. And the fill inlet depends on gravity, so it will be below that inlet. Don't get it confused with city water, that you screw a hose to. The fresh tank fill you just stick a hose in. May have a label "Potable Water Only" The drain should be a white or clear hose. May be capped or have a valve.
Hope this helps
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-30-2012, 07:25 AM   #3
GM
bclemens's Avatar
Lexington is the same. It is under the bed.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 04-30-2012, 10:32 AM   #4
Thanks guys for the information, the only thing mounted under the bed on the lexington 283gts , between the grey water and black water tanks , is the spare tire, could the fresh water tank be located above the spare tire?
Old 04-30-2012, 10:40 AM   #5
GM
bclemens's Avatar
No...its under the bed, not under the floor below the bed. Lift up the mattress. There should be a removable plywood top. Take that off and the fresh water is under there sitting on the floor in the bed base.
