Old 04-02-2012, 09:02 PM   #1
Wanderluster
OffPavement's Avatar
'10 Sunseeker 2300 Coach Frame
Does anyone know if the ladder of a 2010 Sunseeker 2300 is attached to the aluminum frame of the coach?
The Road To Paradise Is NOT Paved!
Brian & Margie
www.rv-camping.org
OffPavement is offline   Reply With Quote
Old 04-03-2012, 07:48 AM   #2
Coachmen Adrenaline
There are backer locations in the wall for where the ladder is attached.
jamiller45 is offline   Reply With Quote
Old 04-03-2012, 08:56 AM   #3
Wanderluster
What exactly are "backer locations"? Metal or wood? Attached directly to the aluminum framework, or weight distribution designed into the wallboards? Any idea of the weight design limit?
Brian & Margie
www.rv-camping.org
Old 04-03-2012, 09:19 AM   #4
GM
bclemens's Avatar
Wood backer typically. The ladders are normally rated by the ladder mfg and not the motor home mfg. 250lbs is the norm.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 04-03-2012, 09:24 AM   #5
Wanderluster
Thanks! Exactly what I needed to know! I'm working on a high frequency amateur radio antenna mount and needed to know for radio frequency grounding needs.
Brian & Margie
www.rv-camping.org
Old 04-03-2012, 10:15 AM   #6
Drinkin beer on the beach
Rod Johnson's Avatar
Where are you mounting your antenna?
2014 Silverado 2500 6.6L TD and 4X4
2011 Carson Standard Duty Car Hauler
2012 Forest River Stealth SK2112
Rod Johnson is offline   Reply With Quote
Old 04-03-2012, 11:52 AM   #7
Wanderluster
I'm installing a telescoping mount from Antenna EZ Lifter. Their web site is pretty poor from my browsers perspective, but the product should fill my operating requirements.
Brian & Margie
www.rv-camping.org
Old 04-03-2012, 01:37 PM   #8
What kind of options are out there for trailer/RV mounts if you don't have a ladder? Anything you might reccomend for 2M?
I'm going to take my test tomorrow and I already ordered a handheld for use in my truck and while out exploring and riding. Thinking I'll pick up something to hardmount inside the trailer as budget permit.
Old 04-03-2012, 02:06 PM   #9
Wanderluster
Good luck with your test tomorrow!
KØBG.COM is a resource you will want to check out. I don't operate VHF so I can't make a recommendation, but the above site will have some of the best mobile ham radio information available anywhere.
Brian & Margie
www.rv-camping.org
