03-20-2018, 10:33 AM
#21
Originally Posted by rockfordroo
Shame on your dealer for not showing you the location of the breaker/fuse panel and explaining it to you.
One MORE example of a lousy PDI.
I am amazed @ how little some of us know about our RVs !!!
That said I wish I knew more,,, and I have learned a Ton on this Forum !!!
03-20-2018, 10:41 AM
#22
I agree.
When I see threads like this, I often wonder how many people own homes for a couple years and don't know the location of the fuse/breaker box?... or a water pump... or (insert whatever here)
03-20-2018, 11:23 AM
#23
Originally Posted by wcrafter
My camper has 2 GFI,s in it o
ne in the bathroom and one around the counter top in the kitchen....
Originally Posted by Wolverine 1945
Probably both on the same fuse !!!
I don't believe GFCIs are on fuses; I think those circuits are on breakers.
03-20-2018, 11:49 AM
#24
Yes Dan I believe you are right !!!
03-20-2018, 01:12 PM
#25
Unless your RV has fuses like this one, your GFCIs are on a breaker!
2011 Traverse LT, 3.6L, FWD
03-20-2018, 07:43 PM
#26
This is supposed to be a chance for the DW to feel important and needed.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
03-20-2018, 08:31 PM
#27
Originally Posted by kenandterry
Some rainy day you might want to test the various fuses and breakers now that you found the panel. Assembly line workers don’t always label the things the way they should be.....just sayin’
Check all your 12v lights and 120v power outlets inside and out. Btw....do you know which outlets are on your GFI circuit? The GFI Control tester is usually the bathroom outlet. It may feed outlets in the kitchen and any outside electrical outlets.
That's exactly what it does
03-21-2018, 08:09 AM
#28
I have not seen one of those in years !!!
03-21-2018, 09:01 AM
#29
Certified Curmudgeon
You might be able to find some collectable pennies behind them.
Mike Dropped
03-21-2018, 09:23 AM
#30
Probably a lot of old homes burnt down by those old pennies !!!
03-21-2018, 09:38 AM
#31
Remember the glass ones?
Larry
03-21-2018, 10:00 AM
#32
Yes !!!
Maybe a little safer ???
Or they seemed that way ??
