Old 03-18-2018, 12:03 PM   #1
Sunseeker
12 Volt Fuse Location
This has probably been discussed previously but I havenít been able to locate the thread. Anyhoo, I have a 2014 Sunseeker 3170DS. I canít get the kitchen or living room ceiling lights to operate. All the under cabinet lights throughout the camper work, as well as those in the hallway, bathroom, bedroom etc. Iíve checked the bulbs in the fixtures and they all work in other locations. I checked the main battery control panel, but donít see any fuses in there for 12 volt service. Is there another dedicated panel for the 12 volt system. Any help would be appreciated. Thanx in advance.
wingunder is offline   Reply With Quote
Old 03-18-2018, 12:12 PM   #2
Just as confused as you
Scrapper's Avatar
Some ceiling lights have both a wall switch and a switch on the light fixture. Both need to be turned on for the light to work. Look for a toggle or push button switch on the fixture.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 03-18-2018, 12:21 PM   #3
Sunseeker
Yes mine has a wall switch for each location, in the control panel above the fridge as well as a rocker switch on each fixture itself, no luck with those. I just assume Iím not getting power to those control panel switches hence the question as to fuse locations?
Old 03-18-2018, 12:54 PM   #4
Scrapper's Avatar
12v fuses are in the same panel as your 120vac breakers unless your Sunseeker is different than most. I don't know if there were LED's that lit when a fuse was blown for that year. If there are LED's then look for the one lit, the fuse will be next to it. I think the light switches need to be on for the LED to light.
Richard & Jill
Old 03-18-2018, 01:00 PM   #5
Sunseeker
I’ll give it a look with the switch on, thanks
Old 03-18-2018, 06:01 PM   #6
Sunseeker
Scrapper,
I found my fuse/breaker panel. It’s on the base of the bed. Never saw it before today. And you’re right, a red led lit up when I turned on the overhead light switch. Tried removing the fuse but when I wiggled the fuse the lights popped on.... go figure. But thanks for your help. Wife is happy��
Old 03-18-2018, 07:03 PM   #7
fliper74's Avatar
Originally Posted by wingunder View Post
Scrapper,
I found my fuse/breaker panel. Itís on the base of the bed. Never saw it before today. And youíre right, a red led lit up when I turned on the overhead light switch. Tried removing the fuse but when I wiggled the fuse the lights popped on.... go figure. But thanks for your help. Wife is happy��
Wingunder,
I feel your pain. I am sitting here laughing my ass off because I went threw the same thing looking for the breaker panel last year when my ac went out. Found it on the base of the bed also. At least they could have put it at eye level.
fliper74 is offline   Reply With Quote
Old 03-19-2018, 12:37 PM   #8
Wolverine 1945's Avatar
Originally Posted by fliper74 View Post
Wingunder,
Not sure you would want it @ eye level ???
I thought ie was pretty easy to see @ the foot of the bed !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-19-2018, 01:32 PM   #9
bikendan's Avatar
I don't ever remember seeing the fuse/breaker panel higher than floor level, in any RV.
Equalizer WDH
Old 03-19-2018, 02:46 PM   #10
fliper74's Avatar
Yea pretty easy to see while you lay on your stomach!!! Ha ha
12 volt, cat, fuse, location
