Old 05-12-2014, 05:23 AM   #1
12V DVD player in bedroom 3170DS
I am looking for dvd palyer for the bedroom in my 3170DS. Since there is only a 12V outlet on the slide I am limited on options. I was thinking about getting a 12V adapter for an old Play Station 2 and a 12v splitter. It looks like the 19" Jensen draws 3.3A and the play station 5.3A. Does anyone know what the limits are on this outlet?
lowreyfarris is offline   Reply With Quote
Old 05-15-2014, 09:12 AM   #2
I brough a sony Blu-ray it had a 12 converter .
2014 sunseeker 3170dsf V10
cruiserjohn is offline   Reply With Quote
Old 07-16-2014, 07:31 AM   #3
DMezzoprete's Avatar
I ran into the same problem as you did with my 3170ds. I just went out and bought a cheap 12V splitter and a converter that converts 12V to 120V. I plugged the Jensen TV into one of the 12V outlets and the converter into the other 12V outlet. Then I plugged a DVD player into the converter, and so far, all seems to be working well. The worst thing that can happen would be a blown fuse, which is very simple to replace. I attached a picture of the converter and 12V splitter I used. Hope this helps! Click image for larger version
Name:	ImageUploadedByForest River Forums1405513779.434126.jpg
ID:	58286Click image for larger version
Name:	ImageUploadedByForest River Forums1405513881.622134.jpg
DMezzoprete is offline   Reply With Quote
Old 07-17-2014, 05:40 AM   #4
I had the same inquiry last year. the only thing to be wary of with a splitter is exactly the question you are asking....If you over-load it, it can over-heat and can create a flame. if you are doing what we contimplated, the splitter will be behind the TV concealed by the closet panelling. I too want the confidence that splitting the TV to plug in a DVD player is going to be safe. I have never gotten this assurrance (though nobody has explicitly said "Don't do it" either.
I am leaning towards a combo TV/DVD/Blueray that operates on a 12V....More expensive but less risk.
Scooter81 is offline   Reply With Quote
Old 07-17-2014, 05:49 AM   #5
Perhaps BClemons could inform us of the make and model of the TV/DVD combo currently being installed on the new models. If I understand previous deiscussion FR has opted for this over the co-axial from the dash unit as most of us have
Old 07-17-2014, 07:36 AM   #6
I guess you are correct about the flame hazard...I never thought of that before but I'm glad you brought that to my attention. But anyways, when I had my previous motorhome before I bought my Sunseeker, I used an Insignia 32inch 12V tv with a DVD player built in for around $200 and it worked great.
Old 07-17-2014, 08:04 AM   #7
I have a Sony BDP-BX320 that has a 120 volt adapter that changes it to 12 volt. According to the spec sheet it draws just under 10 watts with the adapter. I also have a Vizio E-Series E241i-A1 24-Inch that draws 26 watts. Those together are about 3 amps.
Filthy Beast is offline   Reply With Quote
Old 07-17-2014, 12:04 PM   #8
Have the Sony also AND put a 12 volt plug on it and did away with the converter and works fine just use y cable
Old 07-17-2014, 04:20 PM   #9
GM
bclemens's Avatar
Well, currently we are using a Furrioun 12V TV/DVD combo because it was mobile rated. You can't just buy any TV/DVD combo because the DVD does't last long with the vibration.
We were using sky worth for a while (which was Marine based) but I think they kept running us short. So we're now using the Furrion. I met with the owner of the company this week and took at look at their engineering and testing facility. Pretty cools stuff coming from them that is geared towards RV's.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 08-22-2015, 12:50 PM   #10
I did the same thing as DMezz did to power a 120VAC media player up. Put a dc splitter on and never have had any problem. the converter also has a few usb ports on for charging cell phone etc. its a slick setup for viewing all your media formats while drawing little power when boon docking. I use one in the outdoor kitchen also as the Jensen tvs don't play many digital formats. I have a posting on here somewhere that outlines what I use for all.
RON
asparky is offline   Reply With Quote
3170, bed, dvd, roo
