Old 08-30-2015, 07:32 PM   #11
When we picked up our 2014 Sunseeker I asked the dealer for a winterizing kit. And I received the same one I have always received with all our travel trailers. You unscrew the pump inlet and put the winterizing line onto the pump inlet and the end of the hose goes into the anti freeze jug. Switch on the pump and antifreeze is pumped thru all lines as you open the taps/ outside shower toilet Etc. and that's it for winterizing. Not much to it and have never had any issues.
Brandon 2
brandon 2 is offline   Reply With Quote
Old 08-31-2015, 09:27 AM   #12
I did the bypass kit on my 2015 3010. In case anyone is looking to do this, it isn't real difficult, but I made a mistake not knowing too much about the clamps that are used from the factory. I installed everything with no problem, but I used a regular hose clamp at the very top where I cut the plastic tubing under the fresh water tank. I only use the fresh water tank once a year on a longer trip so it took me about 5 months after I did the job to realize it leaked where I used the hose clamp. Luckily I have a neighbor that's a plumber and he had the crimping tool and the correct clamp to do it correctly. I originally didn't put back the same type of clamp because that tool to do it was around $70 and I thought a regular hose clamp would work.
Brian217 is offline   Reply With Quote
Old 09-01-2015, 12:29 PM   #13
Doesn't the pump pull FROM the tank and not TO the tank? I thought that when I flip the switch to bypass the tank and use the antifreeze intake line that the pump takes the antifreeze straight into the coach and not the tank. Is that right?
2015 Forest River Forester 3011 DS - 2007 Dodge Durango Toad
ORvideoguy is offline   Reply With Quote
Old 09-01-2015, 01:50 PM   #14
You're correct. It's not pulling water out of the tank when you bypass. It pulls it from the hose connected to the by pass valve straight into your water lines.
Old 09-01-2015, 10:13 PM   #15
Ok that's what I thought. So I'm still a little confused.
I have a 2015 Forester 3011 and it came with a bypass and a hose for antifreeze already as part of the plumbing. It is accessible in the same door as the pump and the tank empty valve. The OP states he is adding the bypass kit to a 3015 Sunseeker 3010. Does the Sunseeker not come with the bypass already installed. Or is it being added for something else?
Old 09-02-2015, 04:25 AM   #16
Correct. The 3010 doesn't come with the bypass already installed.
jjlavin is offline   Reply With Quote
bypass, pump, water, water pump
