Old 04-04-2014, 09:03 PM   #21
The pic of the small square tube is NOT mine. It's another new Sunseeker on the lot. I think it was 3020? The other 3170 on the lot also had it.
2013 Sunseeker 3170DS
MKrase is offline   Reply With Quote
Old 04-04-2014, 09:04 PM   #22
All other pics are of my unit.
Old 04-04-2014, 09:07 PM   #23
Garrette's Avatar
I hope Clemans chimes in. My unit was one year old on march 28. I wonder if this a factory retro or dealer. If factory, why were the Sunseeker owners not notified.
I hope you get everything repaired to your satisfaction. I guess I will be looking for a cross tube tomorrow.
Garrette is offline   Reply With Quote
Old 04-04-2014, 09:14 PM   #24
Garrette's Avatar
Originally Posted by MKrase View Post
Garrette, see if yours have a slight inward pitch to them
I will check them in the morning. There are a lot of 3170 owners here, maybe they will chime in and post pictures of their jacks.
Old 04-06-2014, 08:13 PM   #25
Here is a pic of another Sunseeker that has the brace. Despite it being small, I would imagine that a tube can hold quite a linear load. Attachment 49143
I saw the cross brace on later Sunseekers and was planning to add one to my 2012 3120. Looks simple to make, a couple muffler clamps and a square steel tube you can pickup at a Home store. I thought it was there to help stabilize the side motion or wiggle when on the jacks. However it probably was added to prevent frame damage as discussed here. Looking at it's design I think it is a very simple and effective solution that will add significant frame torsional strength by counteracting the loading caused by the offset jack brackets. Since both jacks are both trying to bend inward under load this simple brace will essentially allow each jack to help each other to stay straight.
ATVer is offline   Reply With Quote
Old 04-07-2014, 08:50 AM   #26
parpar1's Avatar
As a side note, from day one I noticed that both rear jacks sit at a slight inward angle. I can see that the brackets welded to the frame are cut with a slight angle. Here's a pic of the right rear. You can see just a slight angle, and nothing is bent. It's more apparent with the jack down. Attachment 49144
I have a 3010ds on a Ford. I just installed some Big foots. Mine both angle in just a bit as said earlier and i do have the leveler cross member installed. Per Big Foot you must install this cross member. Now i want to go look at mine too.
OP Sorry you are going thru this. Did you have the back wheels off the ground?
parpar1 is offline   Reply With Quote
Old 04-07-2014, 08:53 AM   #27
Not quite off the ground, but definitely close. Auto leveling usually puts at least one wheel in the air even after multiple calibrations. I know people say it's not the best idea, but no where in the manual does it say not too.
Old 04-07-2014, 12:05 PM   #28
This seems to explain why it happened. Common sense would say that lifting even one wheel off the ground especially the rears (the frame there is the weakest due to being extended past the part made by Ford) puts a lot of strain on the frame components. My rule is if it takes lifting a wheel off the ground to level the coach, either find another more level spot or go to another site. You could also use leveling blocks. My FR manual does caution against lifting the coach by the jacks and cautions to be sure each jack is solidly contacting the ground thus carrying load. It is not easy to tell this without reaching under to see if you can move a foot or looking closely to see some ground penetration of the feet. In auto I have found the system to often not meet this requirement. The manual then says to retract and try auto again. I usually use manual mode. Although I understood the working and cautions of the system my dealer during the walk around spent a good deal of time reinforcing proper jack operations.
Old 04-07-2014, 01:10 PM   #29
parpar1's Avatar
When i first dropped my jacks this weekend it acted real funny. The front of the rv was on the concrete pad and the rears were in gravel. After they all made contact i started to raise the front and it seemed like it was not lifting the front up hardly at all. I then went to drop the back and it jolted down about an inch like they got stuck or had a heavy side load on them jamming them. Then when i tried to lift the left side it seemed that only the front was moving. I worried the frame was twisting. i retracted all four jacks and then tried again. This time it worked perfect. I think the rears where sinking in the gravel and trying to "slide" to the inside (towards each other) a bit. I wonder if i did not have the cross bar on the rears and would have just kept trying to get it level that first shot i may have ended up like the op. It is starting to sound like i made a good choice getting the manual system.
Old 04-07-2014, 01:26 PM   #30
I tend to use manual almost all the time. Maybe if the site is already level and I am just using the jacks for stabilization I will use auto. I'm glad FR put the control panel on a cord so I can watch the jacks especially in manual. Other manufacturers often permanently mount the control panel inside somewhere. I have no idea how someone could properly operate in manual from inside the coach.
2013, 3170, bent, frame, jacks
