Old 07-21-2014, 07:10 AM   #1
2014 3170 DS Questions
Three questions:
1. How can I have the radio on in the cab but not blasting through the coach? (Kids sleeping) if possible see question 2.
2. Is it possible to play a DVD in the coach (through dash dvd) with radio on in cab. Tired of listening to what kids are watching in back.
3. Park cable- I cannot figure this out. While camping we cannot get cable, I am sure I am missing something. Hook the cable up from post to coax (located in drivers side rear compartment) scan for channels under cable setting. It takes forever and gets nothing. I am sure I am missing something.
Any help would be great! Thanks!
rdeiss is offline   Reply With Quote
Old 07-21-2014, 08:42 AM   #2
Hello. Make sure the antenna amplifier is turned off, button is located in the cabinet located over top of the kitchen table. The button is located on the cable wire jack. Also, tighten all the cable tv connectors, mine were loose from the factory. Hope that helps.
Am544 is offline   Reply With Quote
Old 07-22-2014, 07:27 PM   #3
GM
bclemens's Avatar
1. use your fader
2. I think the cross volume would be a big issue. Magnadyne radio?
3. What Am544 said.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 07-22-2014, 08:57 PM   #4
1. Fader (front/rear) in radio sound options
2. I don't have DVD player in dash (Jensen radio). Kids just use the DVD player/radio in the back "kids zone" to watch there movies, play Wii, or stream Netflix.
3. What AM544 said. However, without assuming you know...You have to switch the TV signal from "Air" to "Cable" within the TV's menu setup normally close in the menu where you tell it to search for new channels.
2011 Sunseeker 3170DS - 30,000 miles explored
funfinder5 is offline   Reply With Quote
Old 07-22-2014, 10:44 PM   #5
Thanks for the replies. I will try to find the fader and adjust. Yes magnadyne radio. As far as the cable goes there is not a amplifier switch / button in this unit. I just hook up cable to the jack outside. Scan for channels under cable setting not air and get nothing. Not sure If I am missing a step or what, but do not get anything on any TVs. All connections seem tight so just a little confused.
Old 07-22-2014, 11:00 PM   #6
GM
bclemens's Avatar
So you have a switch box then? Make sure the connections are in the right spot in the back of the box.
You can also test by just feeding the "from cable" connection to the TV directly. The box needs to have the switch set to cable.
Old 07-22-2014, 11:24 PM   #7
Yes I have the switchbox. I have never really figured that goofy thing out. I will check and see what it is on. I have been afraid to mess with after finally just figuring out how to use the DVD player. Thanks for your help
