Old 09-08-2019, 09:09 PM   #1
2014 4500 relay problems
RV will not start traced it to bad relay I HAVE replaced it 3 times this is the chevy van platform anybody else having this problem
sunseeker5 is offline   Reply With Quote
Old 09-09-2019, 05:05 PM   #2
Hoglou's Avatar
I feel your pain... but the miltiple failures is a head scratch. Had this once and gone thus far.
Maybe changing part vendors... also since most relays on that board are the same number ��(see my feb post below) have you used up your on coach parts or are they all new purchases? BAD BATCH?
Old post:
I'm posting this in the C Section for those chevy 6.0 folks like me instead of the electrical forum. I had a starting failure that was repaired while I was on the road as a relay in the fuse panel. Quick and easy all is well. So I get home and look at the relay (like 5 same number relays in the box for varied apps), mine all had the number of 13502750.
Great, easy enough I thought I will pick up a spare and leave it in the coach. So went to the local big box counter and was told it looks alot a like some we have but the numbers are different.
Given the doubt of those pesky little details of the relay guts I went home to look it up myself..
Here is what I THINK I know, the 2750 above replaced by
15328867, replaced by
19115082, replaced by
191156058, replaced by
D1780C which is also known as a10071A1.
If you know otherwise please chime in before I buy a spare (10$)....
Hoglou westGA
BK the DW
KM4HQQ 146.640mhz
Check out the "mods" in the albums
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Old 09-11-2019, 01:43 PM   #3
relay
Thanks , just replaced last original relay will see if that does it
2014, 500, sunseeker
