Old 03-17-2014, 10:42 AM   #1
THarlow's Avatar
2500TSC where are water heater bypass valves
Looked in the obvious places, under bed, near water heater- haven't found bypass valves yet- can anyone with a Sunseeker 2500TSC provide any hints?
THarlow is offline   Reply With Quote
Old 03-17-2014, 10:43 AM   #2
fonzie's Avatar
Have you look behind water heater inside trailer?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 03-17-2014, 11:51 AM   #3
THarlow's Avatar
No, I removed the waste basket and see hot and cold lines to sink, but no apparent valves for shut off.
Old 03-17-2014, 11:55 AM   #4
fonzie's Avatar
Here is picture of typical valves at water heater shown in by-pass position.
Fonzie
Old 03-17-2014, 02:01 PM   #5
THarlow's Avatar
Thank you fonzie, alas this is not the configuration of a Sunseeker 2500TSC. Are there any readers with direct knowledge of the whereabouts of the bypass valves for the requested Sunseeker?
Old 03-18-2014, 12:46 PM   #6
RV Nomad
water heater bypass
It is behind the panel under the sink on my 2500 TSF. Remove 4 screws to access.
xgzx is offline   Reply With Quote
Old 03-18-2014, 09:18 PM   #7
Exactly...at least on my 2014 2500TSC. Alternatively, you can pull out the drawers to the left of the panel and access the bypass. Six of one, half a dozen of the other...
Goatdog is offline   Reply With Quote
Old 03-22-2014, 10:01 AM   #8
fonzie's Avatar
THarlow did you find your by-valves?? would be nice to know.
Fonzie
Old 03-22-2014, 11:46 AM   #9
THarlow's Avatar
Fonzie, yes found the bypass valves, open cabinet blow sink, there's 1 shelf and then a panel at the bottom, 4 screws- access behind panel.
Old 03-25-2014, 07:06 AM   #10
Scootdawg's Avatar
I have the 2900 and I have to remove the drawers under the sink and reach in to the left and I can turn them.
Scootdawg is offline   Reply With Quote
water heater, water, heater, bypass, 500, valve
