Old 07-24-2016, 08:41 AM   #1
2860DS Air Suspension
I seem to be thinking of thins to ask this morning about my RV. Anyway, I have the air suspension on the rear of my Sunseeker. What is the best pressure to ride with to reduce the bounce from front to back? Or is it just poor front shocks and need to be upgraded?
Jack Harcourt
Virginia Beach, VA
jharcourt is offline   Reply With Quote
Old 07-24-2016, 09:38 AM   #2
grumpy0374's Avatar
Many previous posts on this. It all depends on how much your rig weighs, and especially how much of that weight is placed over or rear of the rear axle. The airbags have a maximum psi of 100 psi, and you should never run them "empty"
Always keep 10-20 psi in them, don't let them go "flat"
Most run around 50 psi, but if your loaded , 60-70 psi may be the better psi. You will have to experment to get what is comfortable for you. Start at 50 or so and go up or down 5 psi at a time till you find what's right.
Be aware, the airbags themselves are fairly small, and you can overfill them VERY quickly, from flat to over 100 psi in a matter of 10-12 seconds or so.
When you add air, just kind of "blip" them a second or two at a time.
Grumpy
Steve & Cheryl + Charlie & Casey, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
Camping trips this year so far...8
Days camping...75
grumpy0374 is offline   Reply With Quote
Old 07-24-2016, 08:40 PM   #3
trdutch's Avatar
I use a 12v rechargeable travel compressor.It has many uses for camping but the best use is inflating the bags because you can see the PSI increase on the built in gauge.
I run 70 with all my regular gear
Mine do bleed down over time but if I pump them for a weekend trip they stay up. Over a week and they start loosing pressure
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 08-02-2016, 10:07 PM   #4
I agree I pump them every trip as they do loose pressure. I run them around 90 because I pull a trailer with atv. Seems to be pretty stable. I also had all the shocks upgraded after the first year. Also made a difference
Pacostaco is offline   Reply With Quote
Old 08-03-2016, 01:10 AM   #5
Dmks's Avatar
We have a 2860 and I run air bags at 70-75
2015 Forest River Sunseeker 2860DS
Dmks is offline   Reply With Quote
Old 08-10-2016, 09:23 PM   #6
I have a 2860 and run mine at 55 and sometimes around 30 if I haven't put air in recently. But I haven't really tested more pressure than that.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
suspension
