Old 05-08-2014, 05:44 PM   #1
2860DS Slide Info Needed
Can anyone confirm for sure the socket size to use to manually retract the slides on the Sunseeker 2860DS? I forgot to check it and want to get a socket before I go get The MH at my wifes parents house. I have a drill 1/2" adaptor, extension and flexible joint. Just need the 1/2" drive socket size to fit.
asparky is online now   Reply With Quote
Old 05-09-2014, 09:36 AM   #2
bclemens's Avatar
I thought it was 5/8"...but I always carry a set. You never know when you're going to need a tool. Someone else might be able to confirm that...not at the plant today.
PLEASE do not send questions via Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Old 05-09-2014, 10:55 AM   #3
I was having trouble getting to it without taking the mattress off, my wife will hold it up and I'll fit it.. Looks like a 5/8 or so but I'll report after the test run this weekend
Old 07-25-2014, 11:56 AM   #4
digger47's Avatar
I have had a 2013 2860 for 3 seasons now and was not aware of a manual crank for the slides.
Could you send the location for the bedroom and living area?
digger47 is offline   Reply With Quote
Old 07-25-2014, 02:12 PM   #5
The one under the mattress about a foot out from end of slide... you'll see a nut that looks like the head on a scissor jack.. I haven't looked for the one under the front room slide. I have the couch Seems I saw you can get to it from under couch or from under outside by lifting up on sealing rubber.. cant remember for sure... You wont find a crank for it... get a socket that will fit and an adapter for a drill motor.. I hear it takes forever to use a ratchet on it... I also used a swivel joint as the angle is a little hard with the drill or ratchet
