Old 11-20-2017, 05:04 PM   #1
2860ds slow awning and dropping slide
My second 2860ds 2017 has a very very slow awning extending or retracting, and on a seperate issue when extending the living room slide it drops quite a bit (about an inch or more) when about half way out, then comes back up and extends normally. has any body else had these issues? my first 2860ds a 2015 didnt have eighther of these problems.
gasgastwo is offline   Reply With Quote
Old 11-21-2017, 09:08 AM   #2
SeaDog's Avatar
The speed of the awning may just be different motors used or gearing as long as it extends and retracts I wouldn't worry about it. My slide does something similar and I assume it is the slide coming off the middle set of rollers so far I have not seen a problem.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 12-29-2017, 01:16 PM   #3
My 2014 2860 slide did that then gear box broke. Had to remove full slide to get complete new slide arm and gear box . I'd schedule a service
retired on a mountain is offline   Reply With Quote
Old 12-29-2017, 01:22 PM   #4
Old 12-29-2017, 07:07 PM   #5
My big slide on my 3010 DS drops about and inch on opening. Itís never been an issue. Works fine. I keep it lubed all the time.
MikeRP is offline   Reply With Quote
Old 01-03-2018, 05:42 PM   #6
Garrette's Avatar
Guys, I have a similar setup as shown in the picture. Mine does not DROP down. Now, when retracting, the bottom of the slide/pivots up a bit on the last inch of travel. I assume this is setting the outside face flush to the side of the wall. We did have a drive pin shear in the drive but was repaired without removing the slide. I will give this more study.
Love to see more pics of the slide box opening. The posted picture has a lot of information.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
awning, slide
