Old 02-28-2015, 04:45 PM   #1
2860ds tv
Cab radio/dvd player plays on tv over bunk fine. But can anyone tell me if it should play to bedroom tv or the outside tv aswell. The bedroom tv has its own dvd built in and only has coax cable running to it and not the 3 colored cables which over cab tv has. outside tv only has single coax aswell. Didnt know if i should be able to pickup radio/dvd on all televisions or not?
gasgastwo is offline   Reply With Quote
Old 02-28-2015, 05:17 PM   #2
tmhyer's Avatar
It wont play through all 3 at the same time.
tmhyer is offline   Reply With Quote
Old 03-01-2015, 12:07 AM   #3
chrismbrock2009's Avatar
Plays on all of mine at the same time
2014 Sunseeker 3170ds
Global Wedding Photographer
chrismbrock2009 is offline   Reply With Quote
Old 03-01-2015, 05:14 PM   #4
GM
bclemens's Avatar
May play on all at the same time on older units. That one had a switch box, but the conversion made the picture quality less than ideal. So instead we just mount each TV with its own DVD player. Front-Dash, Outside TV-DVD below it, Bedroom-built in.
Each will get a better signal and more functional if you want to watch separate things.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 03-01-2015, 07:29 PM   #5
Thanks for replys, dont mind that it cant play to all, just means that i can stop trying to figure out now if it would. Outside tv did not come with dvd player that i can find, so i installed a radio/dvd player in outside kitchen so i can play through tv or have radio outside
Old 03-01-2015, 10:41 PM   #6
Same with mine 2014 2860, I added a blueray player and a wii in the cabinet behind outside tv.
Pacostaco is offline   Reply With Quote
Old 03-02-2015, 08:50 AM   #7
GM
bclemens's Avatar
Ah, yes. the 2860 TV does not come with a DVD player.
