Old 02-10-2012, 06:26 PM   #1
MotocrossCamper's Avatar
2890ds towing capacity
One last question for the day.
It's about -18 below zero right now so I don't want to go uncover it and climb inside. Does anybody know how much this unit can tow?
MotocrossCamper is offline   Reply With Quote
Old 02-10-2012, 10:54 PM   #2
GM
bclemens's Avatar
Fords can typically tow 5000lbs. 2890DS puts you pre-2004...so it's possible it had a 3500lbs hitch.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-10-2012, 11:04 PM   #3
Thanks, I will check on the hitch, the chassis is 03, camper was made in 04
Old 04-23-2012, 03:54 PM   #4
I have a 2012 Georgetown 3600 motor home, hitch specs 5000lbs, can I feel comfortable towing a 2004 silverado extended cab gvw about 4600
shortrnd is offline   Reply With Quote
Old 04-23-2012, 06:29 PM   #5
GM
bclemens's Avatar
Should post this in the Georgetown sub-section. This is a Sunseeker Class C forum. Not that you can't post here...but you may get a quicker response in the Georgetown forum.
