Old 08-07-2013, 03:09 PM   #11
Mega Member
Electric Water Heater
Mine is more of a switch; however, it is likely the case that one is "on" and the other is the "off" electric for your water heater. (Of course, also not likely good that they are 'rotted' as this may indicate that they may not make 'contact' to properly function.) You might be able to tell which one is currently depressed by feeling; however, if you do not have water getting hot after a little while, push the other one and that should be the "on." (Assuming that the contacts are not corroded and neither of them function.)
Hope that helps!
rgarner is offline   Reply With Quote
Old 08-07-2013, 03:21 PM   #12
Hope that helps!
thanks.
going out there to try now. I dont want to get zapped because you cant press the rubber button with your finger going through the hole in the rubber.
2003 Sunseeker 2900LE
Bigstatik is offline   Reply With Quote
Old 08-07-2013, 04:09 PM   #13
Denver, CO
garbonz's Avatar
Originally Posted by paulmlac View Post
Clarifying question. Does it fill (if empty) by just turning on the pump or do you also have to turn on a hot tap?
Hot tap has to be on, or da water has no place to pump to.
2017 Fuse 23T
Old 08-07-2013, 04:11 PM   #14
Originally Posted by Bigstatik View Post
thanks.
ok, those rubber buttons are the reset. its a plastic flip switch near the bottom. elec water works, yay.
red led rocker switch inside that says "heater" is just for propane water heater?
Old 08-07-2013, 04:12 PM   #15
Denver, CO
garbonz's Avatar
thanks.
some heaters don't have electric, some have a switch inside the camper, and some have a small switch below those button you are talking about.
2017 Fuse 23T
Old 08-07-2013, 04:13 PM   #16
Denver, CO
garbonz's Avatar
Hope that helps!
Those buttons are probable the limit switches not the on off switch.
2017 Fuse 23T
Old 08-08-2013, 05:10 AM   #17
Electric switch is on the heater itself, accessible from the outside. Lower left corner somewhat hidden. Inside switch is for propane. Both can be used for faster recovery as propane is faster, otherwise use electric from campground and save your propane.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 08-08-2013, 05:22 AM   #18
Those buttons are 'reset' buttons for (I think) overtemp protectors. WRT using electric heat, once tank is filled, you'll find a switch nestled behind the pressure relief valve labeled on-off. Turn it on with a/c power on coach and the heater should heat.
Geri is offline   Reply With Quote
hot water, water tank, water, tank
