Old 02-19-2013, 09:26 PM   #1
osgood's Avatar
3010DS AV question
My wife and I are picking up our new 2013 3010DS on Saturday from Tom Raper. So Excited!!!
Question is... I noticed on the AV switch box that there is a outside AV selection but I cant seem to see where the coax jack is. Is that just an option on the box, or should there be a coax jack out there somewhere?
I use Satellite while out so I assume that I will have to make some changes to the coax input on the driver side connection. I have had to do this on all my trailers before this so I am assuming ill have to put a sat splitter in front of where the coax goes into the antenna booster?
osgood is offline   Reply With Quote
Old 02-19-2013, 11:05 PM   #2
osgood's Avatar
Also
Also, are all 2013 3010ds models standard with Gas/Electric Water heater? I did not see an electric option on the house control panel.
Old 02-20-2013, 05:55 AM   #3
FR uses Dometic water heaters. The electric on-off switch is on the heater itself. Remove the outside access door. It is in the lower left corner, partially hidden behind the gas line. It should have a pin in it that needs to be removed to operate. A good reminder that turning it on with no water in it will fry the element.
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 02-21-2013, 09:25 AM   #4
GM
bclemens's Avatar
That option is just part of the box.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-23-2013, 12:35 AM   #5
Congrats on the Sunseeker! I got mine from Raper also last June. We love it. Picked up some TPMS a few weeks ago to install.
Still figuring out the AV system but I love the camper so far. We should compare notes. Are you towing 4 down?
MikeRP is offline   Reply With Quote
Old 02-23-2013, 12:37 AM   #6
If you are going to be at the Columbus store, I will be there in the morning also. Good luck!
Old 02-23-2013, 08:03 AM   #7
osgood's Avatar
Tpms?
Old 02-23-2013, 08:07 AM   #8
Tire pressure monitoring system
Old 02-23-2013, 08:13 AM   #9
osgood's Avatar
Ahhhh. I should have know that. I have dealt with that in my jeep.
Yes. We are picking up our 3010 today at the Columbus store. Then heading back home for a overnight tinker-athon. Loading it all back up with our gear. I may have them dewinterize it for us so we can use it tonight as she goes to the warm garage when we get back home.
Old 02-23-2013, 08:18 AM   #10
Great. I'll probably be there around noon. If I see you I will say Hi! If not I'm willing to share any questions you may have.
