Old 04-05-2019, 06:27 PM   #1
3010ds dinette bottom cushions (3) re-upholstery
I've got a 2012 Forest River Sunseeker 3010DS purchased new in 2013 that the vinyl upholstery has began to flake off on the cushions and rinky dink couch. I've replaced the couch with the Rec Pro Double Recliner and now need to do something with the wrap around dinette bottom cushions. They unzip. Does Forest River sell replacement covers for this or will it be necessary to find someone local that can re-upholster these? Appreciate the advise and best option money wise.
humblegoe is offline   Reply With Quote
Old 04-05-2019, 09:48 PM   #2
A32Deuce's Avatar
I found someone local to do mine. Made all new with softer foam. Much more comfy.
A32Deuce is offline   Reply With Quote
Old 04-05-2019, 10:06 PM   #3
A32Deuce's Avatar
I also had my couch recovered with more padding. Does not hurt my back to sit on it now. Having them redone, you get to add or subtract padding and also what material and quality is used. Couch now looks like an old time barber chair!
Old 04-05-2019, 10:45 PM   #4
U can order directly from recpro to match ur double recliner.
dmarlo is offline   Reply With Quote
Old 04-05-2019, 10:47 PM   #5
They also sell the material so u could have them made to match. We bought the recliners in toffee in Dec, but the cushions f dinnett have been out of stock. Will probably end up buying fabric and making.
Old 04-06-2019, 06:13 PM   #6
Delco Bobby's Avatar
Did you use Foam Outlet?
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is offline   Reply With Quote
Old 04-06-2019, 09:52 PM   #7
A32Deuce's Avatar
Shop that did it had the foam. He let me pick from samples. But you could get it there.
Old 04-06-2019, 11:03 PM   #8
I was wondering because I have used Foam Outlet in Essington but I suspect they moved to your side of the river.
2018 Ford F-150
