Old 05-03-2016, 06:57 AM   #1
3010ds door latch
There are two stars headed bolts in door latch. These studs sometimes cause problems when shutting door. Can I remove them? What is their purpose?
izzaboomer is offline   Reply With Quote
Old 05-03-2016, 07:21 AM   #2
3010ds door latch
You can move them in or out. I think when there is some movement with the door while traveling it can change where they hit the plate on the door frame. I got to a campground one time and couldn't shut my door until I adjusted those bolts you're talking about. I don't remember which way they had to go, but that did the trick. I always carry that tool now in case it needs adjustment again.
Brian217 is offline   Reply With Quote
Old 05-03-2016, 07:32 AM   #3
The heads of the bolts sometimes do hit the door frame and make it very difficult to shut the door.
Old 05-03-2016, 04:47 PM   #4
GM
bclemens's Avatar
That is a DOT requirement in case of an accident as I recall. It is only for motorhomes. Trailers won't have those latches...no one is riding in while in transit.
There are two ways to do it. Those two bolts, or you can use an automotive rotary latch. Looks like like a car door latch with a bolt on the frame of the door/car and a c shaped latch that rotates around that bolt when the door closes.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 05-03-2016, 05:42 PM   #5
What are their purpose?
Old 05-04-2016, 07:50 AM   #6
GM
bclemens's Avatar
Required to comply with FMVSS Standards. They are there to prevent ejection and the door has to pass certain testing requirements. A single plunger, by itself would not pass the test. Those bolts basically strengthen the latch assembly so that it can withstand the testing forces.
Old 05-07-2016, 09:34 PM   #7
I had problems on a trip to Alaska where the door was coming unlatched....the deadbolt kept it from actually opening but it was not tight. Playing around with the adjustment on those bolts seemed to help the problem.
jrwalkerpa1 is offline   Reply With Quote
door
