Old 03-30-2014, 06:41 PM   #31
parpar1's Avatar
More notes.
After you crimp the lugs on the power cables wrap them in electrical tape to create a moisture barrier.
After you connect the controller cable connector to the one on the pump assembly wrap it to.
I ended up routing the control panel cable over to where the wires come up just behind the driver seat on the floor near the door. If you pull the plastic body panel cover in the drivers side foot well / entry step, you will see a ton of wires running front to back. just under the plastic black wire routing cover there is a body plug. If you pull that out you can fish the control panel wire bundle thru that hole, up and around the plastic wire routing cover. Then run it along the rest of the wire aft. put the foot well / step cover back in place. it snaps in place. It is now stored under the driver seat in a Tupperware bowl. PERFECT.
Bolting the feet on to the rams was a pain. Save installing them for last so they are not in your way. When turning the nut to tighten the feet on to the rams, the ram cylinder rotates with it. Luckily i had a 1/4 inch thick piece of rubber i was able to wrap around them, I then grab that with channel locks to keep from damaging the ram cylinder.
Wish the pump assembly was on rubber mounts. The pump motor is really loud. Some vibration isolation would help that a bunch. Maybe one day if it really does bug me i will cut some skate board truck cushions in 1/2 and install them between the frame and pump assy.
parpar1 is offline   Reply With Quote
Old 04-02-2014, 10:13 AM   #32
parpar1's Avatar
Pictures
Name:	2014-03-30 13.39.05.jpg
ID:	48996   Click image for larger version
Name:	2014-03-30 13.31.03.jpg
ID:	48997   Click image for larger version
Name:	2014-03-30 13.31.17.jpg
ID:	48998   Click image for larger version
Name:	2014-03-30 13.31.36.jpg
ID:	48999   Click image for larger version
Name:	2014-03-28 15.40.13.jpg
Name:	2014-03-28 15.40.40.jpg
ID:	49001   Click image for larger version
Name:	2014-03-28 15.41.24.jpg
ID:	49002   Click image for larger version
Name:	2014-03-28 15.42.39.jpg
ID:	49003   Click image for larger version
Name:	2014-03-29 16.35.36.jpg
ID:	49004   Click image for larger version
Name:	2014-03-28 18.19.49.jpg
Old 04-02-2014, 10:14 AM   #33
parpar1's Avatar
few more
Name:	2014-03-29 17.14.47.jpg
ID:	49006   Click image for larger version
Name:	2014-03-29 16.36.16.jpg
Old 04-02-2014, 10:41 AM   #34
Nice work. Looks like a factory install.
Bobby
bgilly is offline   Reply With Quote
Old 04-03-2014, 06:38 PM   #35
osgood's Avatar
Very nice work... I am saving this post for my summer install of Bigfoot.
osgood is offline   Reply With Quote
Old 04-03-2014, 11:58 PM   #36
parpar1's Avatar
Let me know if you ever need a picture of something to help you get it done.
One last thing i almost forgot. A good old $1.29 Bulls eye bubble level from ACE Hardware. Now i am done.
Old 04-04-2014, 09:26 PM   #37
Garrette's Avatar
Just curious, what size Tupperware, bowl or flat. Tired of stepping on wires. I think Bigfoot makes a wireless controller.
Garrette is offline   Reply With Quote
Old 04-21-2014, 06:51 PM   #38
parpar1's Avatar
Crap Garrette sorry i did not see this. I was not happy with the tub i had. i need to find one with a bigger foot print and cut the top down to get it under the seat.
Anyways used the levelers twice and love it. it is so much better then having to jump in and out moving blocks of wood...... Love having them!!!!!!!!!!!
Old 04-21-2014, 07:29 PM   #39
Garrette's Avatar
Did you get a cross bar for the rear jacks?
Old 04-28-2014, 07:51 PM   #40
parpar1's Avatar
Yes my kit had it included.
