Old 06-05-2014, 11:58 AM   #1
3050s converter
my converter seems to enjoy blowing fuses. first i can not locate a 35am fuse any place all stores have 30 and that is what i use . when i replace all seems fine for about a month and then we blow a fuse. all my 110 works and none of my dc is off. nothing changes as the unit sits in the driveway with the same shore power, and yes i have a surge protector on it. i check the batteries all seem fine, just do not understand why it blows fuses so slowly thaks for any help
oldnewguy is offline   Reply With Quote
Old 06-05-2014, 12:11 PM   #2
TURBS's Avatar
Which fuse is blowing?
TURBS
"Sabre owners united"
Old 06-05-2014, 12:16 PM   #3
TURBS's Avatar
Like yours ?
TURBS
Old 06-05-2014, 08:52 PM   #4
wesslvm's Avatar
i had same problem on my 3050 this year. Turned out I had a failed battery. BTW, I had to order the fuses (two of them on the converter itself) from Amazon as I couldn't find them locally.
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 06-06-2014, 11:15 AM   #5
3050 converter
a battery going down might explain why i get different readings on battery power. some days at voltage next day below voltage next day high again. also fuse will not blow every time with a battery going weak that would change things thanks for the tip keep on camping
Old 06-06-2014, 11:37 AM   #6
wesslvm's Avatar
Same to you! BTW, I think my bad battery that was causing the problems was actually my chassis battery. I killed the battery by leaving it connected while in winter storage outside for 6 months. Won't make that mistake again!
Honda CRV (TOAD)
305, 3050s, converter
