Old 09-12-2013, 10:23 PM   #1
wesslvm's Avatar
3050S hot water bypass?
Does my 2014 3050S have a bypass kit from the factory?
2014 Sunseeker 3050S
Honda CRV (TOAD)
wesslvm is offline   Reply With Quote
Old 09-13-2013, 06:50 AM   #2
TURBS's Avatar
Simple answer.... yes
It'll be behind water heater.
Turbs
Old 09-13-2013, 06:51 AM   #3
TURBS's Avatar
Most likely similar to this
Old 09-13-2013, 07:14 PM   #4
wesslvm's Avatar
Thanks, I found another post that describes where it is for my unit. Apparently I have to unscrew an interior panel under my fridge to get to it.
Honda CRV (TOAD)
Old 11-12-2013, 08:33 AM   #5
Would be nice to know where you found that post
DrJMB is offline   Reply With Quote
Old 11-13-2013, 04:59 PM   #6
wesslvm's Avatar
Don't recall, but all I had to do I was unscrew the cover under my reefer (inside) to get to the valves which are as shown in the picture above.
Honda CRV (TOAD)
Old 11-13-2013, 05:45 PM   #7
jimdaway's Avatar
Hey wesslvm;
We just took delivery of our 2013 3050S and are loving it although we haven't had many chances to use it!!
I found our heater with bypass in the same location (under the fridge behind the panel).
2013 Sunseeker 3050S
Nights Camping 2014 = 7
"Not all those who wander are lost..."
jimdaway is offline   Reply With Quote
Old 11-13-2013, 06:25 PM   #8
Found the panel and hopefully all water is drain.
Old 11-13-2013, 09:54 PM   #9
wesslvm's Avatar
I used lp air to blow out all my water lines. I considered running antifreeze through my water lines using a hand pump connected to the city water connect outside and drawing off the bottle. This is when you want to bypass the hot water heater (after it is drained/blown out) so you don't waste filling the six gallon tank with antifreeze. I decided against the antifreeze since I was confident my lines were dry.
I also removed my water filter and made sure the housing was empty.
I used about 3 gallons of antifreeze to fill the drain traps and above the toilet valve and into the black and grey tanks.
Wes
Honda CRV (TOAD)
Old 11-15-2013, 12:23 PM   #10
winterising 3050s
remember when you winterize a unit, you need to include the water pump. i put pink stuff in my lines, as i use my during the winter. you have a automatic heater on the ice maker to keep the line from freezing. tank heaters go on also, dc power and temp below 40 degrees rather be safe than sorry
oldnewguy is offline   Reply With Quote
Old 11-15-2013, 01:07 PM   #11
TURBS's Avatar
Wes
Does your unit also include a strainer ?
make sure its emptied as well .
Turbs
Old 11-15-2013, 11:06 PM   #12
wesslvm's Avatar
Does your unit also include a strainer ? make sure its emptied as well . Turbs
Don't know of any strainer...
Honda CRV (TOAD)
Old 11-15-2013, 11:45 PM   #13
TURBS's Avatar
Late model units may have this near the water pump.
Old 11-16-2013, 11:34 AM   #14
wesslvm's Avatar
Yes, I believe I have that. It should have blown dry with the LP air, I would thnk.
Honda CRV (TOAD)
Old 11-16-2013, 11:36 AM   #15
wesslvm's Avatar
Actually, I ran the pump till it lost suction also, but now you have me rethinking.... We had 24 degree night last week so what's done is done.
Honda CRV (TOAD)
Old 11-18-2013, 09:08 AM   #16
That's a water filter. You want to unscrew the clear plastic canister, throw out the filter (get a new one next year), drain any water in the clear plastic canister, paper towel dry the threads, and screw the clear plastic canister back on.
I think it would take A LOT of air to dry it all out.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 11-18-2013, 09:46 PM   #17
Just got done winterizing my 3050S. I had to go out and buy a deep socket 1 1/16 to get the drain plug out of the hot water heater. The unit is only 6 months old and I had a devil of a time getting the plug out. The threads weren't coroded, but the manufacturer must have really tightend it. The anode rod didn't look too bad for 1 year.
johnlantz is offline   Reply With Quote
