09-12-2013, 10:23 PM
3050S hot water bypass?
Does my 2014 3050S have a bypass kit from the factory?
2014 Sunseeker 3050S
Honda CRV (TOAD)
09-13-2013, 06:50 AM
Simple answer.... yes
It'll be behind water heater.
Turbs
09-13-2013, 06:51 AM
Most likely similar to this
09-13-2013, 07:14 PM
Thanks, I found another post that describes where it is for my unit. Apparently I have to unscrew an interior panel under my fridge to get to it.
Honda CRV (TOAD)
11-12-2013, 08:33 AM
Would be nice to know where you found that post
11-13-2013, 04:59 PM
Don't recall, but all I had to do I was unscrew the cover under my reefer (inside) to get to the valves which are as shown in the picture above.
Honda CRV (TOAD)
11-13-2013, 05:45 PM
Hey wesslvm;
We just took delivery of our 2013 3050S and are loving it although we haven't had many chances to use it!!
I found our heater with bypass in the same location (under the fridge behind the panel).
2013 Sunseeker 3050S
Nights Camping 2014 = 7
"Not all those who wander are lost..."
11-13-2013, 06:25 PM
Found the panel and hopefully all water is drain.
11-13-2013, 09:54 PM
I used lp air to blow out all my water lines. I considered running antifreeze through my water lines using a hand pump connected to the city water connect outside and drawing off the bottle. This is when you want to bypass the hot water heater (after it is drained/blown out) so you don't waste filling the six gallon tank with antifreeze. I decided against the antifreeze since I was confident my lines were dry.
I also removed my water filter and made sure the housing was empty.
I used about 3 gallons of antifreeze to fill the drain traps and above the toilet valve and into the black and grey tanks.
Wes
Honda CRV (TOAD)
11-15-2013, 12:23 PM
winterising 3050s
remember when you winterize a unit, you need to include the water pump. i put pink stuff in my lines, as i use my during the winter. you have a automatic heater on the ice maker to keep the line from freezing. tank heaters go on also, dc power and temp below 40 degrees rather be safe than sorry
11-15-2013, 01:07 PM
Wes
Does your unit also include a strainer ?
make sure its emptied as well .
Turbs
11-15-2013, 11:06 PM
Does your unit also include a strainer ? make sure its emptied as well . Turbs
Don't know of any strainer...
Honda CRV (TOAD)
11-15-2013, 11:45 PM
Late model units may have this near the water pump.
11-16-2013, 11:34 AM
Yes, I believe I have that. It should have blown dry with the LP air, I would thnk.
Honda CRV (TOAD)
11-16-2013, 11:36 AM
Actually, I ran the pump till it lost suction also, but now you have me rethinking.... We had 24 degree night last week so what's done is done.
Honda CRV (TOAD)
11-18-2013, 09:08 AM
That's a water filter. You want to unscrew the clear plastic canister, throw out the filter (get a new one next year), drain any water in the clear plastic canister, paper towel dry the threads, and screw the clear plastic canister back on.
I think it would take A LOT of air to dry it all out.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
11-18-2013, 09:46 PM
Just got done winterizing my 3050S. I had to go out and buy a deep socket 1 1/16 to get the drain plug out of the hot water heater. The unit is only 6 months old and I had a devil of a time getting the plug out. The threads weren't coroded, but the manufacturer must have really tightend it. The anode rod didn't look too bad for 1 year.
