Old 08-06-2014, 06:36 AM   #11
Originally Posted by johnlantz View Post
I dropped it off yesterday at the dealer. They have one of those machines that pressurizes the RV so you can then spray soapy water and look for bubbles (aka. leaks). They are confident they will find the leak.
Keeping fingers crossed.
I had that done on my former tt. It does work but slide out units are difficult on the pressurization. They had to really crank up the blower to overcome the air leaking around the slide seals.
bgilly is offline   Reply With Quote
Old 08-09-2014, 05:19 PM   #12
We had a similar situation and the leaks were from the freshwater and drain lines under the bed. I tightened all the connections and wrapped them with self-sealing silicone tape. Problem solved.
donk07014 is offline   Reply With Quote
Old 08-26-2014, 06:04 AM   #13
Good news, got the RV back from the dealer last week and we finally had a nice soaking rain and no leaks. They put caulking around every window and joint they could find on the slide. They said the pressurizing machine didn't find anything (probably didn't have the unit completely sealed). But either way I am happy. They will address the rotten plywood in the off season.
I'm going to invest in a tube of caulking every year and apply generously around every window and joint.
johnlantz is offline   Reply With Quote
305, 3050s, leak, slide
