Old 11-04-2014, 05:27 PM   #1
3050s owners
Need some help on this one, we had a bad storm over the weekend here on cape cod. high winds with rain and snow, took my baby out today to help shake the leaves off. had water dripping down the inside of the passenger door. in the storage area on the overhead bunk was water right at the front and wall felt dry. this is before the seam on the cap., is it possible that the outsde clearance lights are not sealed. coach is only 21 months old but i beleve the warrentry is one year on this. any help would be great keep on camping
oldnewguy is offline   Reply With Quote
Old 11-05-2014, 02:39 PM   #2
GM
bclemens's Avatar
Possible yes. Also check the seal where the cap meets the roof. All those seals should be checked before you put it away for winter.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 11-05-2014, 03:22 PM   #3
called dealer he said 90 percent of leaks are from the lights. seems the way the lights are put into the cap can cause water to pool in that area and if not a tight seal they will leak thanks for the reply keep on camping
Old 11-06-2014, 03:40 PM   #4
so today it is raining again, with no wind. i am dry inside and no leaks. i did go back on some posts that said if you replace a lens you will need to put a sealer on it. i did replace the lens on the passengers side this spring will try that
305, 3050s
