Old 06-28-2013, 02:00 PM   #1
3050s shakedown questions
went on a long trip with new 3050s, have a few questions that i hope someone can answer. 1- lost a clearance bulb over the cab, what is the bulb for that. 2 -latch on dinning table keeps coming loose, so table keeps coming down. someone must have a 25 cent home depot fix for that. 3 found 5 different screws on floor during trip, can not find matches for them. hats off to ford, got 8.6 miles to gallon. does anyone have a bulb list for the outside lighting of the unit ythanks in advance for any help.
oldnewguy is offline   Reply With Quote
Old 06-28-2013, 07:13 PM   #2
Plain Old Member
I can only answer one question and thats for the mystery screws. More than likely, they didn't come out of anything and were left over from construction. May have rolled out from under something. I've found quite the collection, plus some other things during removal of vents, panels and creating access panels. The more panels and compartments you open, the more items you'll probably find. Probably find a bit of sawdust and wire pieces too. Hold onto the screws, you may need them for something later.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
Old 06-28-2013, 08:01 PM   #3
If you have a dream dinette which is coming down only while traveling, I suggest you get an expandable shower curtain rod and fit it between the floor and the underside of the table while traveling to hold it up in a fairly rigid position. Our dream dinette table rattled significantly when going over bumps in the road and we solved the noise problem with a curtain rod which is used only while traveling.
budblack is offline   Reply With Quote
Old 06-29-2013, 08:44 AM   #4
3050s shakedown
it is a dream dinette and come down during driving. i will get a shower rod to fix problem thanks for the tip. oldnewguy
Old 07-01-2013, 10:04 AM   #5
GM
bclemens's Avatar
If its a dream dinette you should not need to do this. There is a lever on the bottom of the dinette. That lever LOCKS the table into an upright position.
Push the table all the way up. There is a metal bar with an "L" shaped end. It should be laying against the underside/bottom of the table...grab that and make it lay on the OTHER side of the bottom of the table.
If that doesn't work something is loose and should be fixed. If you need a shower rod...something is amiss.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 07-01-2013, 01:30 PM   #6
Shake down
thanks for the table , the bar will not lay flat against table. any info on the bulb for the cab over clearance lights or a bulb chart on the different bulbs on the out side
Old 07-03-2013, 10:10 AM   #7
GM
bclemens's Avatar
Might not lay completely flat..but there is a bar that will fit into a white nylon notch. That's what locks the table up. If you post a picture of the bulb/lens I'll see what I can find.
Old 07-05-2013, 10:13 AM   #8
see clearance light by Coach PJG on 6/18/2013 .php this is the same unit as me. how do you remove the lens so you can get at the bulb. there are on screws or any way to get it from the inside.
Old 07-08-2013, 07:44 AM   #9
GM
bclemens's Avatar
The lens pops off.
