Old 03-03-2013, 03:26 PM   #1
3050s water heater
called dealership to find water heater bypass told it is behind the heater, well behind my hater heater is a four door frig. was told by teck to look around so be in that area. is it behind the frig, there is a panel between the frig and the floor. this panel has six screws in it, and does not appeared to have been removed. storage under water heater is one solid piece of plastic hope someone has found it in this unit. planning a camping trip at the end of the month.
oldnewguy is offline   Reply With Quote
Old 03-03-2013, 04:03 PM   #2
Not sure on your model, but same guessing game with mine which turned out to be under the bed. A hint at finding it though is that there is a tube running down from the bypass through the floor to the outside. Find it and the bypass should be right above it
Geri is offline   Reply With Quote
Old 03-04-2013, 02:39 PM   #3
The bypass valves are behind the panel under the refrigerator in my 3051S. The furnace is also there.
Steve
cundie11 is offline   Reply With Quote
Old 03-04-2013, 07:26 PM   #4
thanks
i am not a person that likes to remove things from the rv,but if that is where the valves are i guess i have no choice. we are going away and what hot water thanks
