Old 03-24-2016, 07:11 PM   #1
Eagles609's Avatar
3170DS FW Tank SLOW drain
Anyone else's FW tank drain super slow? It comes out extremely slow taking hours to drain. I have tried opening a faucet, leaving the filler cap off, etc and still just a trickle. I am trying to sanitize it and need to fill and flush repeatedly, at this process it will take days!
2014 Forest River Sunseeker 3170DS
TOAD: 2016 Jeep Wrangler Unlimited - Black Bear Edition
Eagles609 is offline   Reply With Quote
Old 03-24-2016, 09:17 PM   #2
sgtlm17's Avatar
Maybe some debris stuck in drain hose. Try some low pressure air from drain hose into tank see if it clears.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-24-2016, 09:47 PM   #3
Garrette's Avatar
On my 2014 3170, If I have a full 40gal and turn the drain valve a full quarter turn, it takes about 2-1/2 - 3 hours to drain. No debris, no kinks, just a small drain line. I usually start the process and do something else.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 03-25-2016, 06:31 PM   #4
Eagles609's Avatar
Thanks I appreciate the feedback, I guess I need to be more patient lol
Old 03-26-2016, 12:13 PM   #5
I've never timed it, but the 40 gallon tank in our Sunseeker 3100 drains in about 20 to 30 minutes. The drain is 1/2 inch pex tubing with a quarter turn valve.
If you want to speed it up, you could turn on the faucets and run the water pump. It's just clean water so you could let the gray tank drain on the ground.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
3170, drain, tank
