Old 11-25-2015, 01:39 PM   #11
Our 2016 2250LE has a 32" in the center of the bunk area with twin beds on either side. During our initial look-over, I wondered the same thing. I hopped up on the bunk and looked behind the TV to find a 10"ish deep cabinet behind the TV. Waaaait a minute - it is a flatscreen, how do you get to the extra space behind it? There was a big grab handle above the TV. I was tugging on it when the salesman suggested that was a handle to assist in getting up into the bunks.
Then how to get to the space behind the TV?
He pulled on a cabinet pull handle located just under the TV - the panel that the TV is mounted on opened up from the bottom (hinge on top) revealing the space, and has two gas struts to hold it open. The wiring is wadded up in the top of the space, then exits the cabinet through the right wall. The upper section also contains the 12V power port for the TV and the antenna connections with a switch for the amplifier.
Where does your power plug into? Can you see/follow the antenna/input/power leads from the TV?
brucemc is offline   Reply With Quote
Old 11-25-2015, 05:22 PM   #12
Here's the floorplan in our 2250LE; it has the optional cabover twin beds:
(Larger image at http://m4.i.pbase.com/g9/88/791988/2...4.10nbS47x.jpg)
Does your unit have a box/space behind the TV? If so, there's got to be a way into it.
Hope that helps!
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
Old 11-26-2015, 12:44 AM   #13
Farkasb's Avatar
There is plenty of wasted storage behind the TV in the entertainment setup. Here's what a 2401W looks like behind the 42" TV after opening up the panel. Haven't figured out what we'll put up there yet surely nothing that will side around and damage the TV.
Name:	ImageUploadedByForest River Forums1448519499.523407.jpg
ID:	95031Click image for larger version
Name:	ImageUploadedByForest River Forums1448519519.799277.jpg
ID:	95032Click image for larger version
Name:	ImageUploadedByForest River Forums1448519532.939044.jpg
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
