08-17-2011, 11:40 AM
55 Amp, Power Converter Location
I got a new 2012 Sunseeker 3120DS and the power converter went out, the dealer has told me they replaced it but are waiting on the factory as it may have been installed in the wrong spot from the factory. It is located under the bed mounted on the floor directly on carpet, they are thinking about moving it to some storage compartment. Does this sound right to anyone?
I have not been bugging the repairing dealer but as of this weekend it will have been there 4 weeks.
08-17-2011, 12:01 PM
Mine is mounted in the back passthough starage compartment in the middle againest the inside wall. the cord goes through the wall and pluggs into the back of the control panel. under the bed is not a great place but easier to get to than were mine is. Had to place a 12"x6' board between the storage door and the hump in the middle to crawel into the compartment to remove and install the new converter as the storage box itself is only mounted with a few screws and would not support me setting in it. Still only took 15 minutes to replace.
08-17-2011, 12:06 PM
Should be mounted behind breaker panel I would say. Why locate it far from everything?
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
08-17-2011, 12:16 PM
as above post, near the fuses. should have good ventilation. dealer may be concerned abt that. heat and electronics are not good friends.
08-17-2011, 12:29 PM
breaker box is built into the foot of the bed, so that is about as close as it gets.
08-17-2011, 12:46 PM
too fast turbo sled
wow ! they must be back logged ..... i replaced my 55 amp with a 70 amp intelli power in about 2 hours since i was modding in the intell-power into my wfco unit . otherwise a 45 minute job .
of course if there moving the unit that will take time to re run all those wires ...... i couldnt imagine .
08-17-2011, 01:42 PM
Thank for the comments. To there credit they had other issues to deal with besides this, they said they where waiting on the factory to tell them what to do. They decided to install the replacement in the same place so if it burns up real quick guess they will have to move it. Also to there credit they say I was called and a voice mail left last Friday, guess I just missed that call.
Does anyone know for sure where this converter should be installed in this model? Or anyone that has a 3120DS where is yours located?
08-17-2011, 01:55 PM
too fast turbo sled
Personally I would put some vents in the bed sides and maybe go to radio shack and get a 12 volt mini computer fan to circulate air. Maybe a low temp heat switch so that if the temp gets to say 80 degrees the fan comes on to cool the area.
as I said before it would take ALOT of rewiring to move that thing.
maybe it was just a faulty unit to.
when you go camping next turn on enough 12 volt things you can to get convert er fan working and stick a thermometer under bed to see how much heat its making.
08-18-2011, 07:22 AM
Forest River Class C's
We used to put it behind the breaker box, but with the fan cycling on and off all the time was noisy in the bedroom. So where we can, we remote mount it.
08-18-2011, 08:12 AM
So is under the bed mounted on the floor on the carpet is where this one should be mounted on the 3120DS?
Another question is, should I leave the coach plugged up to shore power all the time to keep the batteries fresh? If so I would think the temps in the summer would be brutal inside as I do not leave the A/C on.
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 497 |
| 110 members and 387 guests |
| abrowe, aquaskiman, autorot8, Barney1, bend302, biggie, biken201, Biscuit, BlakeB, Bob_Loblaw, boubou, buzzmonster, cheatham09, chof16, Christopher Columbus, COcamper, Cowracer, Crusader, cyclepuck, danred, dansa122, deerslayer, dimurrrw, dummin4fun, Dunefam, dunnnc, EdJunior, f1100turbo, F22, flc, fonzie, frankm, georgetown, gjcamann, GMS, GRAYSONH, Greene, gregory, gsjp1989, Gulay, Happy Campers 79, Happy Vibe, hd87sportster, herk7769, hotrodj125, J R, jacksum2, jes520, joess, JohnHoaglun, johnthecamper, jtstromsburg, Juss82, J_KHawthorne, Kalacim, kamp k, Kevin-and-Julie, KKapa, kybaja, KyDan, lbhird, LFugate, Lonewolfcry, Lostdog, Macgyver89, Mad4sax, Magnetic, MayorBobK, mdrucker, mtnguy, NanaKaren, NancyTX, OffPavement, ohioflyer, Ovair, pandkm, ParkManCan, pbetz, pbrackney, Pharmofish, pip, pixleys, Pkdennis0504, polkatronron, poohbearntigger2, Ragin Cajun, rawlus, rgmiller32, richludden, Rickstermn, rkswyo, ronhanson, Rugged Brown, Rustymax, scott1k, scout800, Scouter, shurack24, Silverado09, sledhead77, Triguy, trudinator, tshayn, Vernk, Vic, vlite2011, Warrior, Wildhog56, Wildwood Danny, wnytaxman |
| Most users ever online was 996, 05-22-2012 at 11:04 AM. |
