Old 06-22-2016, 07:11 AM   #11
Wolverine 1945's Avatar
The reason you want to use 6 volt batteries is ???
Wolverine 1945 is offline   Reply With Quote
Old 06-26-2016, 10:15 AM   #12
2012 Sunseeker 2650CDS
Bought 2 deep cycle 12 v from Costco. Cheap. Good enough for someone that rarely boondoggles. Thanks for the help.
Sunseeker 2650
mrwiensie is offline   Reply With Quote
Old 06-28-2016, 12:00 PM   #13
I put in deeper box for the 2 6v batteries.
NorSnrub is offline   Reply With Quote
Old 06-28-2016, 12:07 PM   #14
Pod2Vibe's Avatar
Originally Posted by johntaylor View Post
I would be very surprised if it did. It's designed to detect propane. Aerosols such as hair spray will also make it go off because they contain butane, which is the next hydrocarbon up from propane. Hydrogen is not a hydrocarbon.
You must have an older rig that just has a propane detector....
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 06-28-2016, 12:09 PM   #15
Pod2Vibe's Avatar
Originally Posted by Rich.M View Post
Dimensions can vary by brand/manufacturer even for the same group size. Agms tend to be smaller for the same group size for some companies. With research you may find your 3/4 inch. Post your final battery choice so we all learn what fits. I went with group 31 12 v Agm .
Hi Rich, which brand/model did you go with for your 24R?
Pod2Vibe
Old 06-30-2016, 09:20 PM   #16
6 v battery
I got a deeper battery box for my 6 volters.
battery
