Old 06-20-2016, 09:52 PM   #1
2012 Sunseeker 2650CDS
6v battery won't fit in sun seeker
Time to replace my batteries (2-12 v). Want to replace with 2- 6v but won't fit in my sun seeker battery well. Only have 10 1/8 inches height and need 11. Batteries are in the step coming in to the coach. Anyone overcome this problem?
Sun seeker 2012
2650
Sunseeker 2650
mrwiensie is offline   Reply With Quote
Old 06-20-2016, 11:16 PM   #2
camaraderie's Avatar
Just get a good set of 12V real deep cycles that fit.
Group 31's will give you 210-220 a/h a pair... measure about 13L x 6,75W x 9.5H
Group 27's will give you 180-190 ...measuring 12.5 x 6.75 x 9.37
Get whichever will fit.
Suggest Trojans or Deka Marine Master DC series or equivilent East Penn private label.
Good luck.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 06-21-2016, 12:27 AM   #3
or make a spacer to raise the step up enough to clear the terminals, longer bolts for the step....
poorbuthappy is offline   Reply With Quote
Old 06-21-2016, 06:12 AM   #4
Rich.M's Avatar
Dimensions can vary by brand/manufacturer even for the same group size. Agms tend to be smaller for the same group size for some companies. With research you may find your 3/4 inch. Post your final battery choice so we all learn what fits. I went with group 31 12 v Agm .
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 06-21-2016, 09:25 AM   #5
I went with US Battery group 31's (130ah) for my Forester.
US Battery 31DCXC 12 Volt 130Ah Deep Cycle Marine Battery
2011 Forester 3171DS Pic
SOLD!
New Rig: 2018 Tiffin 32SA
torino421 is offline   Reply With Quote
Old 06-21-2016, 01:04 PM   #6
I picked 2 Batteries at the area Costco $76.00 ea. and they work great.
goots is offline   Reply With Quote
Old 06-21-2016, 01:23 PM   #7
Chuck.C's Avatar
If you need Group 24 size, try these
24TMX | Trojan Battery Company
2013 Coachmen Mirada 35DL
Chuck, Susan, and dogs- Gracie the Registered SnackHound and Toby the Wonder Boxer
Chuck.C is offline   Reply With Quote
Old 06-21-2016, 01:28 PM   #8
Word of caution. If you put spacers under the step and leave an air gap the batteries will vent to the coach and set off your explosive gas alarm.
RubberNail is offline   Reply With Quote
Old 06-21-2016, 07:11 PM   #9
I would be very surprised if it did. It's designed to detect propane. Aerosols such as hair spray will also make it go off because they contain butane, which is the next hydrocarbon up from propane. Hydrogen is not a hydrocarbon.
johntaylor is offline   Reply With Quote
Old 06-21-2016, 09:06 PM   #10
Well, been there, done that and it did. Maybe your monitor is different, or mine is more particular, but left a gap after adding water to batteries, and alarm went off about every 3 or 4 hours. Noticing the step was loose, tighten up the screws, sealing the box and alarm went away. Others on other threads have noticed the same problem when batteries get old and start to give off more gas. That's when I suspected that could be the problem and discovered I had not tighten the screws.
In any case, if shimming the steps, a simple screen door gasket will likely seal the box sufficient to prevent vent gas from entering the coach.
battery
