Old 06-14-2016, 04:09 PM   #1
A/C Condensation? 2014 3010DS
We went camping this past weekend in Three Rivers, a family Sequoia trip. I had the a/c set to 70 degrees and the fan was set to auto. I noticed water dripping from the cabinets over the dinette area. There were drops falling from two separate spots. I checked the interior of the cabinet and they were dry. I'm assuming that the humidity, combined with the kids constantly opening the door, caused heavy condensation..I switched the fan to high instead of auto and it seemed to fix the problem. Any advice or if anyone has experienced this please let me know..
Thank you
RSMSunseeker is offline   Reply With Quote
Old 06-14-2016, 10:11 PM   #2
Chief tinkerer
Gidyupgo's Avatar
RSM, we experienced the condensation along the ceiling duct path on a recent trip to the coast. Opening the AC dump vent on the unit took most of the flow out of the ducts and stopped yhe ceiling drips. There may be other/better methods out there, but this worked for us. We still stayed cool.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 06-15-2016, 09:34 AM   #3
Sunseeker 2400MBW
Hey, we just got MH and I don't know what a dump vent is or where it is? Is it on the roof? Thanks.
Nancyc7 is offline   Reply With Quote
Old 06-15-2016, 10:55 AM   #4
Chief tinkerer
Gidyupgo's Avatar
Sorry 'bout that Nancy. I dont know what it is called so I named it by what it does. Standing directly under the unit looking up there is a grill that is closed. See if there is a couple of tabs that you can grab and slide the plastic plate under the grill one way or another to open this to allow direct air flow straight down on you.
Gary
Old 06-15-2016, 11:19 AM   #5
TURBS's Avatar
Quick cool dump is the appropriate name.
Sent from my SCH-R530U using Tapatalk
Old 06-15-2016, 03:41 PM   #6
Sunseeker 2400MBW
Thanks, I will look at this. I want to avoid any water! anywhere! but where it is supposed to be!
Old 06-15-2016, 04:29 PM   #7
The condensate forms at the cooling coil on the roof inside the AC enclosure and should drain onto the roof and not enter inside your RV. You may want to check the drain to make sure it is not plugged.
2012 Lexington 265 GTS
clhjsh is offline   Reply With Quote
