Old 11-18-2017, 02:44 PM   #1
Ac and heat run at same time
Need some help, when I put my tstat on funace mode the a/c and furnace both come on but in cool mode only a/c.
Mike3393 is offline   Reply With Quote
Old 11-18-2017, 02:48 PM   #2
sgtlm17's Avatar
Put your thermostat in fan mode. Press the plus or minus key til fan says auto. Do not select hi or low. Once fan is in auto you can now set thermostat to furnace and your furnace will operate without the ac fan coming in. For a visual on how to do go to YouTube and search 'dometic single zone lcd thermostat'
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 11-18-2017, 02:53 PM   #3
Mr. Dan's Avatar
Yep
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 11-18-2017, 03:39 PM   #4
Thanks works great!!!
Old 11-18-2017, 05:33 PM   #5
2012 Solera
FYI - unless you have a heat pump, your AC isn't coming on - just the fan, which can be useful to circulate the air while running the furnace (also, the continuous "white noise" from the fan in the AC unit can help mask the noise of the furnace cycling).
JLeising
2012 Solera "S"
Calif SF Bay Area
