Old 11-14-2012, 09:29 PM   #11
Jean & Walt's Avatar
Thanks for the help.
Jean & Walt is offline   Reply With Quote
Old 11-14-2012, 09:37 PM   #12
VinceU's Avatar
Originally Posted by 123WHPJTP321
Does this work for the AC? We are new to RVing - AC fan runs constantly only the compressor turns on and off!
Yes as above set fan to auto to cycle with compressor.
Old 05-31-2015, 06:56 AM   #13
Thanks! Y'all just saved me from digging out the manual on our maiden voyage. Dealer prep guy said to leave fan on high always.
2016 Sunseeker MBS 2400R + Diesel Gen
2014 Honda CRV
Blue Ox Flat Tow Equipment
SMI Stay-In-Play Brake Controller
ericlakin is offline   Reply With Quote
Old 05-31-2015, 07:19 AM   #14
Why did the the dealer prep guy say that? Sounds like a statement not based on fact.
biznsa is offline   Reply With Quote
Old 05-31-2015, 07:47 AM   #15
Herk7769's Avatar
Sounds like a "boondock" guy.
I have heard this is a technique to reduce start up amperage when running on the generator.
Since the compressor and the fan motor have peak amperage draws during startup that drop after the motors are on speed, a generator operating at the margins may not be able to handle starting the fan and the compressor concurrently.
I solved this problem by installing a fan delay relay allowing the compressor to start up first, followed 5 seconds later by the fan motor.
Just cut the fan wire coming from the thermostat and connect the ends to the two lugs on the relay. Do not cut the jumper and turn the dial all the way to the left (plus a smidge).
HAM CALLSIGN - KC3FFW
Old 05-31-2015, 07:38 PM   #16
I had a control board replaced on the AC on my 2012 Sunseeker under warranty in 2013. Since then, the compressor starts first and then the fan (both AC and heat pump).
2012 Forest River Sunseeker 2300 Chevy
RvBill3 is offline   Reply With Quote
Old 06-02-2015, 10:24 AM   #17
Puzzlme's Avatar
I love this forum. Have never needed the furnace before when plugged in. This morning I turned it on and had the same issue. Within minutes I had the solution simply by checking this forum. Thanks.
http://rhodaventure.com/
2013 Sunseeker 3010DS
2014 - 15,000 Kilometers (9360 Miles) Alberta through the US to E. coast, up into Atlantic Canada, Newfoundland and back.
2015 - 2 great trips so far. Alberta to Oregon coast, Alberta to Shushwap in BC.
Puzzlme is offline   Reply With Quote
fan
